Results 1 to 4 of 4
Thread: Silvia with Auber PID Problem
    May 2011
    Sunbury, Victoria, Australia
    2
    Hi all, first post but long time reader.
    I have a Silvia Ive had for a few years that I purchased with the Auber PID mod. I "think" it has steam control also as I vaguely remember being able to set a setpoint for the steam temperature.
    The problem is, I had a play around this morning with the brew temperature setpoint, and in the process have managed to fudge the settings I think. I have long lost the instructions I received from the original seller, which I dont think were standard instructions / settings.
    In any case, everything is working perfectly except for when I try and heat up for steam. Turn the machine on and it heats up to 109 C. It brews on the timer. I normally then hit the steam switch, and it would get to around 135 C. It is not heating at all at this point past the normal setpoint (109C).
    Is it possible I have changed a setting in the Auber or has something gone wrong?
    Any advice would be greatly appreciated, otherwise I think it might be time for a trade up. ::)
    Oct 2010
    483
    Re: Silvia with Auber PID Problem
    If it is heating to brew temp, it is either the pid, or if you still have the original stream thermostat, that may have failed.
    I have an auber manual on the computer at home (still at work so cant check right now), but the manuals are available on the web. Itll be an auber SYL (SYL 1512 maybe). Have a look and if you cant find one, pm me your email and Ill send it to you.
    May 2011
    2
    Thanks for the offer of help. Much appreciated.
    I emailed Auber at the same time as posting here yesterday and this morning had an email from them with suggestions, and the manuals.
    Happy to see we are back in action and it was just a misconfiguration with the 1512B PID.
    Ill attach the files here for anyone else in future looking for them.
    Thanks again.
    Oct 2010
    483
    The operation manual for the kit was one Ive not seen before. Not only very well written, but informative for users of other PIDed espresso machines.
    Interesting to see the steam control is handled the same way as Firepower documented for his Gaggia and uses simple on/off driven by the alarm output. They confirm there would be no benefit in a dual setpoint PID for a machine that struggles to maintain temp while steaming.
  1. !!!SOLD!!! - Rancilio Silvia v3 auber PID
    By samboye23 in forum SOLD
    Last Post: 29th November 2011, 12:19 PM
  2. Auber PID Silvia Lag problem
    By rjstokes in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th July 2011, 11:03 AM
  3. Replies: 6
    Last Post: 24th November 2010, 05:18 AM
  4. !!SOLD!!: Silvia with Auber PID
    By preeves in forum SOLD
    Last Post: 23rd August 2010, 08:34 PM
  5. Auber PID for Silvia questions
    By NewToEspresso in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th April 2008, 10:04 PM
