Results 1 to 4 of 4
Thread: Tech help needed with "Little" brand, lever machine
    Apr 2007
    137
    I bought this machine ages ago, was told it needed a new element. I had the machine sent to a coffee machine place and they told me the element was fine and it works well for what it is. Received a few days ago and it does heat up water fine.
    Its a very basic machine, on/off, no steam wand and a lever to draw the water through.
    The problem is I cannot get the lever to go up, nor draw any water through. I have tried with/without water in the boiler, I have pulled the machine apart and tried to bring the whole assembly out of the group without success. It just feels like its jammed completely.
    I cant find schematics at all, anyone know anything that might be able to help me out?
    Cheers.
    PS. I have attached a few small photos.
    PPS. Not my house :)
    Apr 2008
    Brisbane
    5,113
    Re: Tech help needed with "Little" brand, lever machine
    Without actually seeing it and having a calculated guess
    I would say that the piston and spring mechanism is seized
    Apr 2007
    137
    Kosmo,
    what would you recommend to remedy this?
    we came to the same conclusion, and tried using a cooking oil to free it up (dont really want to spray inox in there).
    Apr 2008
    Brisbane
    5,113
    In general & it applies for all things mechanical
    First check the easy things? Is it just coffee oils that have solidified
    If not
    Strip down, clean, new seals & re assemble
  1. "Closed" Coretto advice needed.
    By sidewayss in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 3rd July 2011, 10:13 PM
  2. Iberital grinder doser lever "misses" every now & then
    By bushblockies in forum Grinders
    Last Post: 12th January 2011, 10:03 PM
  3. "Favorite" brand, anyone heard of them?
    By iamsam in forum Grinders
    Last Post: 16th December 2009, 07:49 AM
  4. Which Cafe "Brand"?
    By Beanhead in forum General Coffee Related...
    Last Post: 27th June 2008, 09:10 PM
