Results 1 to 4 of 4
Thread: Gaggia Baby Dose - pump failure?
    Jun 2010
    9
    Hi all - my Gaggia recently stopped working after 3 or so good years of useage! It seems like the pump has given up the ghost. It makes all the sounds but nothing is being pumped through - well a few drops but nothing like it should be putting through.
    Has anyone else had this problem - if it is the pump is it worth getting it replaced or shall I just look at investing in a replacement machine?
    Its been a great machine for me twinned with the Sunbeam Cafe Series burr grinder.
    Somebody help please!! :)
    Apr 2011
    19
    Re: Gaggia Baby Dose - pump failure?
    My Gaggia Classic recently began exhibiting the same simptom. Any advice would be appreciated.
    Failing trouble shooting myself (reasonably handy DIY guy) Looks like a trip to a service man - any suggestion on where in Melbourne....
    Cheers Rob
    Site Sponsor
    Aug 2006
    929
    Quote Originally Posted by 5E5B565F5950483A0 link=1306024497/0#0 date=1306024497
    Check the follow:
    1. Shower screen not block (undo this with a phillip screw driver)
    2. Distribution Disc (undo this with Allen Keys)
    If water does not come after this could be the follow:
    1. Blockage on the line between boiler and group head (needs to take boiler a part and give it a clean.
    2. Solenoid not energizing to create pressure (replacement)
    3. Pump not pressurizing any more (needs new pump)
    Regards
    Renzo
    Jun 2011
    683
    Does the pump note change when you switch on the brew? Like a low pitch rising after a few seconds to a steady hum? If so the pump is probably good as it is still pressurising and it will be a blockage or solenoid problem as Renzo indicated.
    If the pump is OK you should also see water flow out of the return from the over pressure valve back into the tank.
    -Rick
  1. Gaggia baby dose - opv
    By sossy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd March 2011, 11:49 AM
  2. Gaggia Baby Dose
    By clubbi4 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 29th March 2010, 09:24 PM
  3. Gaggia Baby dose and baby twin?
    By WSullivan in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th January 2008, 05:53 PM
