Results 1 to 7 of 7
Thread: Help.....Via Venezia not heating
    May 2008
    41
    Hi All,
    I woke up this morning looking forward to nice hot coffee only to discover my machine didnt heat up.
    How can I determine if it is the thermostat or the boiler?
    Is it a DIY (I have changed a steam valve before) Job.
    Thanks Guys.
    Shane
    May 2008
    41
    Re: Help.....Via Venezia not heating
    Hey guys,
    Someone must be able to give some insight to this problem.
    Shane
    Jun 2010
    217
    there will be a brew thermostat and steam thermostat and heating element in series
    thermostat should be closed when cold and go open when it reaches its rated temp
    element should also be low resistance about 10 to 50 ohms depending on wattage
    the brew thermostat will be shorted out by steam switch when steaming, so only steam thermostat is used.
    check if it still gets steam temp, if that is ok then your brew thermostat is broke.
    if not maybe a broke steam thermostat or element or faulty wiring
    you can test all the part with it powered off using a mulitmeter
    thermostats are just simple on or off switches controlled by temperature.
    hope this helps
    May 2008
    41
    Thanks Firepower,
    Yeah, both the steam & brew are not heating.
    Ill open her up & check what you have suggested.
    Thanks Again,
    Shane
    Jun 2010
    217
    do a google for " Wire Diagram Barista 230V 00300373 "
    it give you a wiring diagram.
    here is a jpg of gaggia with circuit diagram, which will give you a better idea how your machine operates
    single boiler machines are all similar , gaggia, Via Venezia, Silvia etc.
    Jun 2010
    217
    there will also be a thermal fuse on boiler , this is shown as 2 in gaggia diagram, it there to protect element if thermostats fail closed. thermal fuse will be open circuit if it has blown, and will need to be replaced.
    looking at diagram of via viencia you have 3 thermostats , boil 95, steam 127 , protect 175
    on the boiler. coffee parts should sell thermostats if you need them.
    your element is 900W = 64 ohms.
    May 2008
    41
    Hi Firepower,
    Just wanted to say thanks for all the info provided.
    The good news is I opened it up this afternoon and it was two burnt out wires. Stripped the ends back replaced the old clip & working as good as new. ;D
    Thanks again,
    Shane
    PS Writing this with fresh (Hot) brew in hand
  1. Via Venezia not Heating
    By joevb in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th November 2011, 08:11 PM
  2. Pre heating HG 5kg
    By redzone121 in forum Roasters
    Last Post: 22nd March 2011, 07:02 AM
  3. Heating from below...
    By Framey in forum Roasters
    Last Post: 30th August 2005, 12:53 AM
