Results 1 to 5 of 5
Thread: Help with Saeco machine, please?
    Jun 2011
    2
    I have a Saeco Incanto S-Class Deluxe machine. I have made the classic newbie mistake by changing my settings so that I get a lot of water dispensed with each grind to fill my mug! As a result a get a woefully weak cup of coffee.
    Does anyone know how to reset the amount of water dispensed to the original factory settings?
    If not, can anyone suggest how many millilitres (ml) I should reprogram the small cup button (espresso) and the normal coffee button with to get a satisfactory cup of coffee?
    Site Sponsor
    Aug 2006
    929
    Re: Help with Saeco machine, please?
    I found this in Mr goggle:
    http://www.gtp.com.au/espressotemp/inewsfiles/saeco-Incanto%20S-Class%20De%20Luxe%20user%20manual%20english-watermarked.pdf
    I think is page 15
    regards
    Renzo
    Di bartoli Home Barista Centre
    Jun 2011
    2
    Thanks Renzo - however, I am still stuck.
    My machine is the same, except that is does NOT have an LCD display.
    Besides, the page you refer to shows how to alter the amount of coffee that is ground by the machine - not the amount of water added to the coffee.
    I have checked the machine for my machine - there is nothing in it.
    Mar 2011
    39
    http://www.coffeeshrine.com.au/user-manual-saeco-incanto-deluxe-s-class-english.html
    So there is nothing in the manual on how to reset to factory settings?
    A small espresso on my machine (Nuova) is 30ml but dont know whether this is the same for all machines (manual vs auto etc)
    I know when I bought my Nespresso quite a few years ago it had all the info about the default settings / what they were / how to reset.
    Did you check the troubleshooting part of the manual?
    Mar 2011
    39
    If you know the model number you can go here:-
    http://www.search.philips.com/search/search?q=saeco+incanto+s+class+deluxe&s=support&l= au_en&h=support&o=
  1. Saeco Pianeta Caffee machine
    By Caroleus in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 4th December 2011, 04:17 PM
  2. Mystery Saeco Machine?
    By Bishop in forum Brewing Equipment (non-machine specific)
    Last Post: 10th July 2011, 09:11 PM
  3. Saeco Coffee machine water tank empty
    By dino2dy in forum General Coffee Related...
    Last Post: 19th May 2009, 06:51 AM
