Results 1 to 16 of 16
Thread: Silvia first day problems
    RJM
    RJM is offline
    Jul 2010
    7
    Hi
    This is my first post although I have been a very regular reader of other peoples posts since I found out about the site last year.
    Today I picked up my Silvia which replaced my La Cimbali Domus which gave me almost 15 years of trouble free service. I was expecting some initial teething problems in learning now to best use the Silvia with my K3 grinder which I bought second hand but almost new last year but hadnt previously used with a machine.
    However after having used over 250gms of beans I have not been able to get any creme out of the Silvia this is despite setting the K3 at its finest setting. I got four baskets as well as decent stainless steel tamper with my Slivia package ( 7,9,14 and 18 gram) and have used each of the baskets to no good effect - all that I am getting to happen is a rush of hot water.
    My beans are not new (they are probably about 4-5 weeks old) and I know I should have bought new beans but I was expecting to use most of the beans experimenting so I thought I would just use them up.
    Has anyone else had similar experiences with a Silvia or is it likely that I might have other problems ie the grinder is not working properly.*
    I would* welcome any help or suggestions anyone can offer.
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Re: Silvia first day problems
    Welcome to CS RJM.
    Doubt you have much to worry about. Its 99% likely that the beans are stale ie. lack of resistance provided by the oils in the beans.
    Step 1 now would be to purchase some fresh coffee.
    Den
    Coffee+carbon=heaven Mono's Avatar
    Aug 2009
    Regional Victoria
    739
    I second the motion, welcome RJM. I also second Dennis diagnosis, stale beans are the likely problem. Surely you have a local roaster with fresh produce avaliable for purchase?
    Steve
    RJM
    RJM is offline
    Jul 2010
    7
    Thanks for the re-assuring advice. I will get some fresh beans hopefully tomorrow.
    Feb 2007
    4,512
    Hmm. Fresh beans available on a Sunday...not so sure.
    If you really, really, get stuck, rummage through the shelves for some of Coles Finest - they have roasted on dates and you might get one less than a month old.
    Nov 2009
    Altona, Melbourne
    1,577
    Quote Originally Posted by 65444F4F4852210 link=1308387066/4#4 date=1308393137
    Easy to do in Melbourne, we have many cafe/roasters that are open on Sunday, not least being site sponsors Di Bella
    RJM
    RJM is offline
    Jul 2010
    7
    I bought some new padre beans that were roasted today by the Brunswick East Project and unfortunately* another 250gms of coffee later there is no real improvement ie just a rush of hot water at the finest setting across a variety of baskets.
    I think it must be a problem with the K3 grinder as the grind should be powdery on that setting and for some reason it is quite coarse. I know it shouldnt be the burrs as the grinder is just over 12 months old and wouldnt have had much more than 10 kgs through it. Does anyone have any ideas?
    Oct 2008
    Sri Lanka
    486
    If youre a newbie (and there aint no shame in that) Id expect around 1-3 kg of beans before you learn to use Silvia correctly.
    Save yourself the time and ask Di Bella if they still do their coffee course - it will save you a lot of time and heartache.
    Also, dont change your baskets all the time - stick with one until you learn. Theres enough variables for you to mess around with in grind, dose and tamp.
    Jun 2008
    1,520
    are you sure the grinder is at its "finest" are you winding right in to "burrs touching" with no beans / clean grinder and burrs then backing off a little and going from there.
    if your using the "numbers" on the grinder they are sometimes not accurate on some grinders (zero may not be zero)
    stupid question, your using a tamper right....
    RJM
    RJM is offline
    Jul 2010
    7
    Thanks again - unfortunately it is definitely a grinder problem - it is just spitting out literally big pieces of coffee beans - the more I fiddle and try different settings including backing it off and resetting it the worse it gets.
    Worse I cant even get into it to the insides of the grinder to check it out as when I bought the grinder second hand last year I didnt get an alan key for it and I have just went to Bunnings and bought a set of alan keys none of which fit.
    This has just been one of these weekends full of hope but ultimately very frustrating and annoying.
    I will try and contact someone tomorrow to have a look at it.
    Jun 2008
    1,520
    take the grinder with you next time :)
    strip it down, it might be full of oils and crap stopping you from grinding properly (jamming the threads of the grinder)
    unless the burrs have been grinding rocks or something is bent / stuffed you should be able to choke the silvia i reckon even with blunter burrs
    May 2011
    6
    Ive had a Silvia for 2 months now, and as a new user have probably put through a 1-2 kilo of beans when experimenting with dialing in the grind and getting the tamp pressure right. But Ive never had chunks of beans spitting out the grinder at me.
    As you suggest if you cant get a fine grind of beans out of your grinder you are going nowhere fast. Hopefully its just a simple problem with the new grinder or how you are using it.
    Do you still have access to the old grinder you used with the La Cimbali Domus? Perhaps run some beans through it for the Silvia.
    RJM
    RJM is offline
    Jul 2010
    7
    I got rid of my old grinder which was a Braun which I used with La Cimbali Domus as it was also about 15 years old. Something just happened on the K3 which hopefully can be easily fixed- unfortunately the output at the moment out of the grinder resembles wood chip.
    KJM
    KJM is offline
    May 2007
    688
    Hey RJM - I have a Silvia and I bought a K3Touch (to use in the Tea Room @ work, but I tried it out here at home first ;) ;) ).
    The K3 has no problems whatsoever choking Miss Silvia.
    The K3T in the Tea room was recently severely abused by someone who wouldnt own up (maybe I was just a bit too cross at the time...). The grinding plates were completely blocked. Not surprising when you put INSTANT into it :o
    If your grinder wont dial in fine enough, it could just be gunk on the threads preventing you dialling in close enough. Spinning off the top reveals all - I had to use a toothpick to clean each burr slot out - it does take time but the grinder comes back to life!
    Hope this helps.
    /Kevin
    RJM
    RJM is offline
    Jul 2010
    7
    Thanks for all the helpful hints from everyone however as it turns out there was a problem with the K3 grinder and thanks very much to Chris from Talk Coffee for helping me resolve the problem.
    Today armed with some fresh beans from Chris I am a lot happier than I was this time last week. I got some good shots by my standard from the Silvia although no where near as good as the standard Chris was able to get with his skills and fine coffee machinery.
    14,665
    Quote Originally Posted by 627A7D300 link=1308387066/14#14 date=1308994370
    Today armed with some fresh beans from Chris I am a lot* happier than I was this time last week. I got some good shots by my standard from the Silvia although no where near as good as the standard Chris was able to get with his skills and fine coffee machinery.
    Thanks RJM,
    I am glad that the issues were minor.
    I found that the previous owner had disassembled the grinder to clean it and on assembly, the top burr had been left waaaaay short of contact with the lower burr, which had not been cleaned prior to reassembly. There was a fair amount of goop in the thread.
    The locking pin in the K3 collar prevented correct adjustment. It was a 5 minute fix to get you up and running again.
    Thanks for the feedback on the coffee. We had some lovely stuff in the grinder yesterday :)
  1. Silvia Problems
    By nanga1972 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th April 2011, 08:26 AM
  2. Silvia with PID and Compak K3 - problems dialing it in
    By SimonC in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th December 2010, 09:59 AM
  3. Newbie - Silvia Coffee Problems
    By marxman in forum Brewing Equipment (non-machine specific)
    Last Post: 22nd September 2006, 08:52 AM
  4. Silvia Problems
    By JR in forum Brewing Equipment (non-machine specific)
    Last Post: 18th January 2005, 09:16 AM
