Results 1 to 15 of 15
Thread: gaggia classic pid upgrade
    Aug 2007
    39
    l have read a few posts on these things and l still have a few questions.
    which temp controler would you use if you want to monitor the steamer and the boiler.
    couldnt you just change the thermo-stat to a hotter one if you arnt getting the right temperture water.
    l deffinitly think it makes sence to know what the temp.is.l was thinking of buying a universal controller SYL-1512 but it looks like l would need 2 if l wanted to monitor the steam as well.
    Is it worth getting a more complicated controller!
    rgs greenbe
    Which
    Jun 2010
    217
    Re: gaggia classic pid upgrade
    you can monitor both brew and steam temp with a PID temp display read out.
    PID is used to control brew temp accurately
    you can also use the alarm out as a basic temp switch* to control steam.*
    (no PID function, just on or off as it crosses the set alarm temp)
    Mar 2006
    703
    I havent tried it with mine, but I have read that you can just reset the temperature to a suitable steaming temp and let the PID do the rest (assuming that your thermocouple is mounted on the boiler as is most commonly done),....
    but easiest way is to just use the steam switch to override the PID, and monitor the boiler temperature display on your PID, and when your boiler gets to say 120 deg, you blow the steam wand out and start steaming and your heating element will stay on for duration of the steaming, which gives good steaming.
    Dec 2010
    94
    Even cheap simple PIDs like my Sestos D1S have an alarm function you can use.
    Ive been experimenting with setting the temperature up 40 degrees from my brew temp, which takes six button presses, then flicking on the steam switch when I start steaming. It works fine if you can be bothered with the buttons.
    Jun 2010
    217
    would not recommend having no temperature control when steaming, boiler will keep heating even when extracting steam, eventually it will blow the thermal saftey fuse.
    either use original steam thermostat or use PID /alarm to control via thermocouple.
    Jun 2010
    217
    Quote Originally Posted by 767A7B747B3B7A77677C707B150 link=1309224532/3#3 date=1309230304
    Should be able to set alarm point once, and then after that only use steam switch, you wire the output of alarm via the steam switch to SSR, alarm is on below 40C and when it gets over 40C turns off , (40C above brew temp)
    Dec 2010
    94
    I dont do enough milk to go to the trouble of wiring up the alarm to control the steam temperature. I still have the steam thermostat in place, Im just resetting the primary PID temperature when I do milk to guarantee not triggering the steam thermostat because it takes so long to get your steam power back after the steam thermostat is triggered.
    16,771
    Quote Originally Posted by 767A7B747B3B7A77677C707B150 link=1309224532/6#6 date=1309236896
    Thats all I ever did too htr.... 8-)
    Takes but seconds to do and keeps everything under PID Control.... ;)
    Aug 2007
    39
    Thanks for the extra info.
    the kit l was interested in has.
    The PID controller in this kit is specifically modified for home espresso brewing applications. Two additional parameters are included to balance the requirement of cold start speed, shot recovery speed and long term stability. (this is a different controller than our universal controller SYL-1512)
    2) A platinum RTD temperature sensor is used which is more accurate and has greater long-term stability than thermocouple sensors. Temperature variations within the controllers environment will not affect the accuracy of its reading. In addition, the sensor is built inside of a screw and will fit into the existing thermowell for the coffee thermostat
    3) All the cables in the kit have high temperature endurance as the original cables used by the manufacture. We use color coded cables with either fluoropolymer or silicone insulation. This will prevent the potential electrical shock resulting from PVC insulated wires touching the boiler during operation.
    it is on ebay in the states has anyone installed one of these units the sound like they would do the job ok.
    rgs greenbe
    Aug 2004
    2,312
    Spanner in works?..........
    Or, instead of spending money (be it ever so little) on this very / very basic espresso machine, you could put it towards something better.
    Just another perspective :)
    Rgdz,
    Attilio
    very first CS site sponsr
    Dec 2010
    94
    Attilio might not be a fan but a Gaggia Classic with a pid and a properly adjusted over pressure valve can give you water at a consistent temperature and a consistent pressure. And consequently great coffee.
    How much would you have to spend to get something that can do that off the shelf?
    Jun 2010
    217
    My Gaggia Baby was about $50 , already had a PID, $20 for SSR + heatsink , $30 for silvia steam wand, $50 for tamper , jug, group brush, blind filter.
    I very happy with results, and it very fast to warm up. will do OPV adjust when i get my pressure gauage.
    I expect it will improve some more after adjustment, have learnt a lot by fitting PID and it was fun and satisfying to do myself.
    Aug 2007
    39
    He has a good point the kit l was looking at is a $150 do you think that l could do it cheaper the crux would be getting the rtd for the gaggia the rest should be off the shelf l think this feature is not something you would get in a standard machine,but you would think when the red light is on or off what ever the case maybe everything should be perfect!But we know this is not the case.
    Jun 2010
    217
    thermocouple is fine for PID , rtd probably overkill, sure it better but could you tell the difference in making the cofffee, PID vs thermostat > big improvement, thermocouple vs rtd > no difference.
    Kit will be easier to install as all the hard work has been done, it has all the parts and been proved to work, it depends how clever you are in researching and buying parts and working out how to install to get what you want.
    Dec 2010
    94
    If you enjoy doing it it is worth doing it yourself from parts. If you dont enjoy tinkering and you put a value your time then you might as well buy it.
    Personally, I enjoy tinkering.
  1. Replies: 6
    Last Post: 15th March 2012, 09:20 PM
  2. Gaggia Classic portafilter and GAGGIA PROTEO ROMANZA
    By cazby in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th October 2011, 06:50 PM
  3. Keep the Classic? Or upgrade?
    By MrRocket in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th August 2010, 11:31 AM
  4. gaggia classic- time to upgrade ($2000)
    By happygilmour in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 4th August 2010, 12:05 PM
