Results 1 to 2 of 2
Thread: Silvia leaky steam arm, which part do I need?
    Nov 2006
    979
    Hello, Ive had my Silvia now for 4 and a half years and its given me many hassle free shots of coffee.
    Recently the slow drip out the steam arm that it always had when idling, has turned into a substantial leak when pulling shots.
    Im wondering if anyone knows which parts are required to fix this?
    Is it a simple case of replacing O rings? Do I need a new valve? Or do I need the steam valve Gasket?
    Thanks, Sam.
    Sep 2007
    Adelaide
    25
    Re: Silvia leaky steam arm, which part do I need?
    Hi Sam
    You would most likely be looking for the valve seal for the Steam Valve. I replaced mine a while back - got it from Coffee Parts over there <---
    When I did it, I replaced the o-rings on the steam arm and the valve at the same time. (Grabbed a group head seal too, but havent needed that yet).
    You will also need some food grade hi temperature grease to lube up the valve thread and the o-rings. I bought the tube available from Jaycar.
    Link to parts page at Coffee Parts (assuming its the same pre-08 model as mine):
    http://www.coffeeparts.com/domestic-parts/machines/rancilio-silvia-08-valves.html
    The job is pretty straight forward, but does require removal of the steam valve from the machine.
    Regards...
    Fraser
  1. Fix for leaky Lelit steam valve (hopefully)
    By scumbag in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th January 2017, 11:30 PM
  2. Leaky Silvia - Melbourne Repair?
    By digitalbugsy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th April 2013, 06:59 AM
  3. Leaky Silvia
    By TimA in forum Brewing Equipment (non-machine specific)
    Last Post: 29th January 2005, 12:12 PM
