Results 1 to 6 of 6
Thread: quiet a silvia
    bwcasolo
    quiet a silvia
    i have used tooth pick ends to quiet the side panels of my silvia. it helped tons. now i think i will get a yoga mat piece for it to sit on. love the machine, teamed with a preciso, and metropolis coffee. any other tips for quieting her down. i will not put anything inside. thanks
    Senior Member artman's Avatar
    Jun 2006
    2,433
    Re: quiet a silvia
    There is a thread somewhere here where dynamat type of material (stick on sound deadening material typically used in car audio applications) was applied to the inside of the panels (was not a sylvia, but principles are the same) which worked well.
    Dom_Collopy
    Re: quiet a silvia
    I watched this earlier tonight and wouldnt mind giving it a go!
    Making the Rancilio Silvia espresso machine silent
    http://www.youtube.com/watch?v=rlZvSj98UkU&feature=related
    Jun 2006
    2,433
    Re: quiet a silvia
    The dynamat stuff is like a thin layer of bitumen, self sticking, and dampens the vibration of panels. The stuff this guy uses looks like a sponge, which would not be ideal if you get a leak, it would soak up and retain moisture. I would say the dynamat would work better.
    I guess the source of noise is mainly 2 fold, metal panels vibrating against each other, and metal panels resonating themselves. The actual pump is not that noisy, its the vibrations from it transmitted to the machine parts that make it sound like a tractor.
    bwcasolo
    Re: quiet a silvia
    thanks, i am concerned of closing it up too much and not allowing the pump to cool off. good suggestions.
    Jun 2006
    2,433
    Re: quiet a silvia
    Thats why I think using the dampening stick on stuff and making sure things are not loose would be worth a shot, it doesnt effect air flow/space. I will do this one day to my Lelit combi.
  1. Shhhh I need quiet...
    By shapeshifter in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th May 2011, 01:01 PM
  2. Quiet Operation
    By SwampRat in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th September 2008, 09:44 PM
  3. Quiet Coffeesnobs?
    By robusto in forum Off Topic
    Last Post: 26th April 2007, 11:38 PM
