Results 1 to 7 of 7
Thread: FrancisFrancis, imat mokita, Quaha Napolitana
    Jun 2007
    6
    FrancisFrancis, Imat Mokita, Quaha Napolitana
    Mmmmm, all of the above. Do they rate well with the Silvia, specifically in achieving a good, consistent frothy milk? Only 2 cups need to be made within, say, 10 minutes.
    Also, ease of use please.
    thank you
    Frank
    May 2005
    1,951
    Re: FrancisFrancis, imat mokita, Quaha Napolitana
    Hi Frank,
    I havent used all of these machines, but I noticed that they all have "froth aider" attachments on the steam wands. Ironically, these make it much harder to get properly textured milk. But if you really want to buy one of these machines, you might be able to retrofit a silvia steam wand to them.
    Luca
    Nov 2006
    979
    just something to check with the fransisfrancis. Im pretty sure that you can only buy them in Australia as an ESE (Illy) pod only machine. I dont think they come with a normal, group/portafilter/bastket. You could get the bits to make it normal but I reckon thats the last thing youd want to do when buying a new machine.
    Feb 2007
    242
    Worth noting that the froth-aid on the quaha/imat comes off to reveal a single hole tip underneath. I make 2-3 lattes for my better half on the napolitana every morning & I get silkier milk than most city cafes.
    Jun 2007
    60
    The Francisfrancisx3 comes set up for pods but you can buy the adapter kit for around $40 on ebay ,for ground coffee.
    Jun 2007
    Melbourne, Victoria, Australia, Australia
    34
    The Francisrancis X1 does have an ordinary porta filter available which you have to buy seperately. I have FranicsFrancis x1, to be honest I would not buy it again >:(. It is the older model where the bolier is aluminium, I believe the newer ones are brass. Its not very consistent probabaly due to aluminium boiler. Steaming is not that great either. Ive had mine for about 4 years and have had the thermostat replaced twice and also the temperature gauge as well. Youre far better of with a Silvia which at least comes with a commercial size porta filter. The FrancisFrancis X1 is sligthy smaller, did I mention the cracked plastic handle on the porta filter :-[ Stay away from it if you can and dont succumb to its looks, my wife did !!!
    Jun 2007
    6
    Yes it does look good. But thanks for the hot tip! ;)
  1. Replies: 3
    Last Post: 16th August 2011, 01:15 PM
  2. Replies: 1
    Last Post: 26th April 2010, 10:05 PM
  3. Imat Napolitana parts?
    By segrave in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th April 2009, 02:04 AM
