Results 1 to 4 of 4
Thread: Cleaning Rancilio Silvia?
    Jun 2008
    8
    Hi
    Have had my silvia since June and was trying to work out whether I should backflush it with cleaning solution? I have been told that nasty things could go wrong :-/ Any thoughts on how I can clean the silvia?
    thanks
    Oct 2007
    791
    Re: Cleaning Rancilio Silvia?
    make google your friend, or do a search here. theres bound to be a stack of info re miss silvia. yeah, the manual says not to backflush - but most people (the informed ones) do chemical backflush. some do it daily, weekly, bi monthly, etc. depends on usage .
    while i wont give u a money back guarantee, backflushing miss silvia is safe (providing you follow some solid backflushing advice, eg not leaving the pump running for a long time with a blind filter). its probably more simple than you imagine.
    cheers
    aaron
    Jun 2011
    17
    Im pretty sure theres some good guides to anti-calcing and backflushing around, but havent gone searching yet. Id be keen to find out too, so let me know if you come up with something.
    KJM
    KJM is offline
    May 2007
    688
    When I had mine, I backflushed weekly. About monthly(ish) Id remove the showerscreen and do a full on clean with cafetto.
    My sister has a Silvia and has never backflushed it. It was no longer working so well :o Removal of the showerscreen was a bit of a shocker! I ended up disassembling the 3 way valve to remove the built up crud.
    All in all it took probably an hour or so. Miss Silvia is a pretty simple machine.
    /Kevin
  1. cleaning water tank and water carrying tubes of Rancilio Silvia from "gunk" ?
    By acid_rider in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st September 2012, 10:24 PM
  2. Silvia Cleaning - Use vs Frequency of Cleaning?
    By Dalspec in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th September 2008, 11:44 PM
  3. Cleaning the Group on a Rancilio Lucy
    By DavidM in forum Brewing Equipment (non-machine specific)
    Last Post: 3rd September 2005, 08:13 AM
