Results 1 to 4 of 4
Thread: Gaggia Baby Dose Problem - Steam Wand Comes Off
    Mar 2009
    3
    Hello,
    Just wondering if anyone else has experienced this issue. I have just bought a Gaggia Baby Dose and the steam wand comes off all the time now. Not the nozzle but the whole steam wand... There is a plastic nut that I can put back into place but after every use it comes off again.
    I need to take it to an authorised repairer (in Brisbane there is now only 1 *I think because now the milk component is unusable.
    Site Sponsor
    Aug 2006
    929
    Re: Gaggia Baby Dose Problem - Steam Wand Comes Off
    hi Euro33;
    I had two already for the same problem, the problem is that this steam arm is hold by a clip or clip holder. You need to be very gently when you clean your nozzel.
    If you go to Shriro Austrlia they are the importers of this machine they should tell you who is your closer agent.
    Good luck
    Renzo
    Mar 2009
    3
    Hi Di Bartoli,
    Thanks for your reply.
    Did you need to take it into a repairer to get this problem fixed?
    Site Sponsor
    Aug 2006
    929
    Is easy to be fix, if you want to take it to the service centre due to is under warranty I thik you can do it.
    if you want it to fix is easy you will need cross screw driver:
    • Take tank out
      • Take the two screws that are nex to the body of the machine
        • take the two crews that are next to the group head they are in font under
          • Take the steam knob out (carefully do not scrash the machine, take the screw under the knob.
            • Take the cover off, you will see the steam hose there, clip it on
              • Put the cover back, test the machine and the job is done.
                Good luck
                Renzo
  1. My Gaggia New Baby with PID and Silvia steam wand mod.
    By Firepower in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 6th March 2019, 12:02 PM
  2. Gaggia Baby Twin - Water instead of steam come out of the steam wand
    By sunbirdj in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 16th June 2010, 01:15 PM
  3. Leaking Gaggia Baby steam wand
    By Ilan in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th October 2007, 09:00 PM
