Results 1 to 5 of 5
Thread: Cafetto in SB6910
    May 2009
    24
    Cafetto in SB6910
    To all those 6910 owners out there, im wondering for those that use Cafetto whether you use it and do a full cleaning cycle as you would with the SB tablets or whether its best to do just a standard water backflush but with the Cafetto?
    I had a bit of a look and found plenty of info regarding using Cafetto in this machine but was unsure as to whether it should be the full cleaning cycle or just a backflush? (and really i guess, how different actually are the two processes?)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Cafetto in SB6910
    Quote Originally Posted by 5C776D766C405C6D707C747A6D1F0 link=1248777619/0#0 date=1248777619
    As stated in a number of posts..
    1: 1/4 to 1/2 a teaspoon in place of the small cleaning tabs and follow the manual.
    2: This is for a group head flush and clean... NOT a full system de scale.
    The full method has been posted by Hoyks and myself a number of times...
    Go here to learn more http://coffeesnobs.com.au/YaBB.pl?num=1248646363
    May 2009
    24
    Thanks AM, Super quick response as ive come to expect from snobs!!
    Off to do it now.
    Sep 2007
    Northlandia
    1,365
    I use option #2, and only allow the pressure to build slightly before I stop the pump - gauge gets to about 9 oclock. This is perfectly adequate to dissolve the cafetto and cause a backflush.
    IMO the self-clean program puts undue pressure on the system, which can lead to problems such as the three-way outlet pipe leaking/detaching at a junction point or the brass outlet nozzle.
    May 2009
    24
    Thanks M@. And other contributers. I did wonder that about the automatic cycle. It really does seem like a backflush for people who dont know how to do a backflush! Gave the old girl a good once over and descale today and she seems very very! Thanks also to the fine produce coming out of the Coffee Barun! These guys really are the bomb!
  1. Using cafetto with SB 6910
    By anuyadav in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th June 2010, 11:53 AM
  2. Cafetto
    By anuyadav in forum General Coffee Related...
    Last Post: 16th May 2010, 11:38 AM
