Results 1 to 5 of 5
Thread: 6910 backflush
    sy
    sy is offline
    Jul 2009
    22
    6910 backflush
    Hi guys,
    Might be a silly question... After a water-only backflush on this machine as part of daily cleaning process - do you need to empty any residual water in the machines resevoir? Does this water get contaminated with dirty water from the grouphead?
    Thanks,
    10,496
    Re: 6910 backflush
    No and No.
    You should occasionally empty and clean the tank as part of your longer term cleaning cycle.
    May 2006
    89
    Re: 6910 backflush
    No, the water from backflushing goes directly into the drip tray via the little drain at the back.
    Senior Member Rusty's Avatar
    Apr 2004
    Carlingford NSW
    691
    Re: 6910 backflush
    Hi SV,
    Sounds as if youre new to the EM6910 ;)
    I highly recommend the free Sunbeam barista course where you will learn how to get the best out of your machine. It covers all aspects of the SB including water back flushing.
    sy
    sy is offline
    Jul 2009
    22
    Re: 6910 backflush
    Thanks Rusty, between the time I made this post and now I have done a stack of reading through posts on this site amd finally got around to doing the sunbeam course last week.
    Thanks to this site and the contributors I basically reinforced my knowledge at the course and did not really learn anything new apart from the fact that the new 6910s have a slightly lower showerscreen which means the instructions regarding tamping are incorrect (ie tamping halfway on the sliver tamp). Due to the lower showerscreen, only 1mm of sliver should be visible on the tamp after tamping. Hope that came out right???
    Any yes, fully aware of how the machine backflushes now.
  1. 6910 backflush blocked ?
    By coffee_hombre in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th April 2011, 11:33 PM
  2. Backflush
    By Coffee_Kid in forum Brewing Equipment (non-machine specific)
    Last Post: 5th September 2006, 09:45 AM
