Results 1 to 4 of 4
Thread: Gaggia Classic Steam Capacity
    May 2006
    47
    I have a Gaggia Classic that I keep at my parents place in the country for weekend visits etc.
    One thing that has irritated me since I bought it (second hand a couple of years ago) is the steam capacity seems to be pretty dismal. It has *just* enough steam for 2 flat whites (say 200-250ml of milk in total). As I approach around 50 degrees I can hear the steam running out and I usually have just enough to get to 60. After that though it is basically blowing air out of the steam wand.
    I just wanted to get an idea from other Gaggia owners whether this is the typical experience with this machine. I know it has a pretty small boiler, but I would have thought it could manage enough steam for 200-250ml of milk. A friend suggested that maybe over time there had been a lot of build up of scale and other crud on the boiler, and had effectively reduced its size. Is this a likely reason for the steam capacity being seemingly low, or is it just a facet of the smaller gaggia boiler?
    Site Sponsor
    Aug 2006
    1
    Re: Gaggia Classic Steam Capacity
    T.D;
    I think the machine is due for a clean, descale the boiler and see whta happen.
    Regards
    Renzo
    Oct 2008
    488
    TD,
    check http://coffeesnobs.com.au/YaBB.pl?num=1126833848
    I steamed an easy 400ml this morning without a worry in the world.
    I have posted in that thread - look at #159 (on page 4).
    There maybe a build up of scale, but I would first read the above thread about tricking the thermostat to maximise your steaming power. Combined with the silvia steam arm mod - you should have a significant improvement. Failing that - a descale and service maybe required.
    Ben
    May 2006
    47
    Hi guys, thanks for your replies.
    I already have the Silvia steam wand mod (sorry, probably should have mentioned that earlier).
    Thanks for that link, I have read most of that thread but didnt realise it also discussed techniques on getting more out of the steam. Ill give that timing trick a go next time I use the machine.
    Its very nice to hear you can steam 400ml without any issues, so clearly there is room for improvement in my machine. I agree that a good descale is probably long overdue (I dont imagine the previous owner ever did it). Will be interesting if that makes an appreciable difference.
  1. Gaggia Classic - No steam, just hot water.
    By Degrees in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th July 2012, 11:16 AM
  2. Gaggia Classic PID Steam Control
    By justinlim26 in forum Brewing Equipment (non-machine specific)
    Last Post: 3rd May 2011, 06:51 AM
  3. Gaggia Classic no steam?
    By Brent_Sydney in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th March 2011, 06:40 AM
  4. rancillio steam arm for gaggia classic
    By hvyw8 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 12th January 2010, 03:35 PM
