Results 1 to 6 of 6
Thread: 6910 leaking?
    May 2007
    Perth, Western Australia
    3,167
    6910 leaking?
    My sons 6910 is leaking water when brewing. I put the blind filter in and backflushed and the portafilter started to unlock itself and leak water everywhere, does this mean that the lugs or collar are worn and need replacing?
    Feb 2009
    North Rothbury, NSW
    1,104
    Re: 6910 leaking?
    It may just be the seal GM
    Id start there first
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: 6910 leaking?
    Quote Originally Posted by 777F676D70140 link=1250206406/1#1 date=1250206495
    Yep.. KISS is the best approch.
    Quote Originally Posted by 736671717A79757A140 link=1250206406/0#0 date=1250206406
    My sons 6910 is leaking water when brewing. I put the blind filter in and backflushed and the portafilter started to unlock itself *and leak water everywhere, does this mean that the lugs or collar are worn and need replacing?
    You going to hate me ;)
    How old is it ?
    How is it maintained ?
    Single or double floor PF baskets ?
    How fine a grind ?
    What sort of tamp ?
    When did it last have a seal replaced ?
    If it has, do you have access to teh Si spacer - Will buy you some time...
    Feel the collar and if you look with a torch etc.. You will soon see / feel how worn the collar might be.. You can do this on its side or upside down..
    WARNING: Remove water tank FIRST...
    Senior Member MeanzBeanz's Avatar
    Apr 2008
    Perth
    111
    Re: 6910 leaking?
    My 16 month old 6910 was doing that plus the GH was at the 5 oclock position. When the pump was running the gh would move to the left and start leaking water. If I held the gh in place it was ok, but who wants to wrestle with a 6910? Problem solved with new seal and silicone spacer. Suspect worn collar and/or lugs. Will be interesting to see how long the fix lasts.
    May 2007
    3,167
    Re: 6910 leaking?
    How old is it ? 18 months
    How is it maintained ? regularly cleaned
    When did it last have a seal replaced ? 5 months ago, but it occasionally falls out.
    Grind and tamp are ok, been extracting good shots.
    Will get a new seal and spacer and see how it goes.
    thanks for the feeback CSers!! ;)
    Aug 2007
    101
    Re: 6910 leaking?
    sounds like your collar is definetly worn, here is a pic of mine which I just replaced.
    It now locks off firm at 6 oclock. From now on I hardly put any pressure on it so I can make it last twice as long. Mine was 18 moths old and I use to give it a good wrench to lock it in. :-[
  1. 6910 leaking
    By C-Train in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th October 2009, 11:24 AM
  2. 6910 leaking puddles
    By moment in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th December 2007, 11:55 AM
  3. 6910 leaking
    By hammer in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd August 2007, 04:38 PM
