Results 1 to 8 of 8
Thread: EM 6910 - brass showing in portafilter, dripping water nozzle.
    Aug 2009
    35
    Issue 1: Brass showing on inside of Portafilter
    Ive just noticed that the inside of the portafilter on my Sunbeam 6910 is losing its chrome - the brass is showing. I have been cleaning it with Citric acid - but have only done this about 4 times. Does it matter if the chrome comes off? Will it affect the taste? (NB - I removed the plastic thingy when I first got it - I believe someone here christened it the "Graeme".)
    Issue 2: Dripping water nozzle
    The hot water nozzle has begun to drip when the machine is doing a pour. Anybody else had this problem? Does it get worse? I am asking because I want to know if it is worth worrying about, as it is not causing a problem otherwise.
    The unit was purchased in January.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: EM 6910 - brass showing in group handle, dripping water nozzle.
    Quote Originally Posted by 3E34393A3A393437383037550 link=1250476712/0#0 date=1250476712
    Ive just noticed that the inside of the portafilter on my Sunbeam 6910 is losing its chrome - the brass is showing. *I have been cleaning it with Citric acid - but have only done this about 4 times. *Does it matter if the chrome comes off? *Will it affect the taste? *(NB - I removed the plastic thingy when I first got it - I believe someone here christened it the "Graeme".)
    Issue 2: *Dripping water nozzle
    The hot water nozzle has begun to drip when the machine is doing a pour. *Anybody else had this problem? *Does it get worse? *I am asking because I want to know if it is worth worrying about, as it is not causing a problem otherwise.
    A: Pealing off in sheets or just fading ???
    Many commercial units (hard core home ) that have been in use for some time have teh chrome worn away...
    B: Dripping water nozzle = possible lack of maintenance and correct cleaning agents etc OR lots of very fine coffee... Or some scale has come away..
    It gets in a little valve :D and allows water to flow in 2 directions rather than one...
    What happens if you turn on Hot Water and leave teh group out... After a while, do you get drips from teh group head ?
    Conclusions... Do a De Scale as per teh manual and then do a back flush as per the manual... Using correct cleaning reagents..
    Then test and let us know..
    Aug 2009
    35
    Issue 1:
    Well, its a relatively new machine, so I was a bit surprised. Its wear rather than anything else - its not coming off in sheets.
    If it doesnt affect the coffee, and is just cosmetic, then I dont care (particularly since it is inside the portafilter!). Thats what I was concerned about - whether having the exposed brass would do something to the flavour (or be dangerous - I dont really know much about the chemical effects of these metals).
    Issue 2:
    Thanks for that - it sounds like a highly plausible explanation. Ill try it out. It is due for a descale. They say every six months, so it is really one month overdue.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 58525F5C5C5F52515E5651330 link=1250476712/2#2 date=1250516447
    Issue 1:
    Well, its a relatively new machine, so I was a bit surprised. *Its wear rather than anything else - its not coming off in sheets. *
    Issue 2:
    Thanks for that - it sounds like a highly plausible explanation. *Ill try it out. *It is due for a descale. *They say every six months, so it is really one month overdue.
    1: Not 100% normal but to be expected... Some are better than others..
    2: Let us know as to Group and getting drip in H Water and when you run Hot Water, what happens on teh Group ?
    AM
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 4B414C4F4F4C41424D4542200 link=1250476712/2#2 date=1250516447
    Brass wont kill you
    Most household taps are made of it + water runs inside copper pipes
    Relax & drink the coffee ;)
    Aug 2009
    35
    Quote Originally Posted by 527D7476615E727D7274767E767D67130 link=1250476712/3#3 date=1250517866
    The group doesnt drip - I ran it for a minute, and filled two latte glasses to the brim.
    Aug 2009
    35
    Quote Originally Posted by 76525B5B58586276524E50523D0 link=1250476712/4#4 date=1250517935
    Brass wont kill you
    Thats what I wanted to hear!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4F45484B4B484546494146240 link=1250476712/5#5 date=1250600660
    So it still leaks a bit from the HW when making a coffee ?
    If so, there is a small valve in the main group head that can have a slight impact but usually for when water comes out the Head, when running HW.
    As the knob opens and closes a valve, the only other thing I can quickly think of it that a bit of scale or crap has made its way into HW valve...
    Unless you very happy with pulling apart... I would not go there.. So where are you located ?
    If only a drip... Wait until ya next clean and descale and run the HW so that the cleaning agent etc gets to make it way via the HW valve / tap..
    Let us know how you go..
    PS. Dropped two groups in to be re chromed (1 = heavy use) and cost me $40... So @ $20 a group = OK cost to have them like new again.
    The second one was a Naked EM6910 group, that I modified to take out the step in teh lug... So it should come back as new and all teh machining marks from being Naked will also be done...
  1. EM7000 dripping water from group head
    By Lukemc in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th December 2012, 02:21 PM
  2. EM 6910 Naked portafilter
    By Brettus in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th March 2012, 11:47 PM
  3. Sunbeam 6910: Horrendous price for new portafilter handle in NZ
    By CJ in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th January 2012, 08:11 AM
  4. Clear Water Dripping around Portafilter
    By sanch in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th December 2007, 08:23 AM
