Results 1 to 2 of 2
Thread: La Pavoni Europiccola - refurb?
    May 2007
    132
    I have a La Pavoni Europiccola (standard model, in chrome) that has some corrosion in the base. It is circa 2000 and paired with a La Pavoni Jolly grinder and the base that they both sit on (which also has some corrosion).
    I was wondering if anyone could suggest what this combination might fetch on the 2nd hand market, as I do not want to spend more on restoring it than it is worth?
    Any advice would be greatly appreciated.
    pip
    pip is offline
    May 2007
    37
    Re: La Pavoni Europiccola - refurb?
    Hi Stucci, the Pavoni lever machines regularly sell on evilbay for around $400 , and very clean examples *for *much more than that.The Jolly grinders dont appear very often at all.
    They are very simple machines to disassemble and reassemble , and spares are available from a Coffeesnobs sponsor at reasonable prices .If there is corrosion in the base that threatens to become structural -the boiler is moving around relative to the base - and its not the base gasket thats perished *; thats *bad, but general corrosion (from drip dray accidents) on the top and the underside of the base is quite normal , and you could get the base re chromed - or just polish it out with a metal polish and use an *anti corrosion spray.
    Theyre great machines when you get the hang of them - and Im still a Pavoni newbie myself , but have managed some great pulls (and rubbish ones too) , and theyre much quicker to heat up than almost anything else- and a tiny footprint on the bench.
    Send me a PM if you have any other questions,
    regards, pip.
  1. La Pavoni Europiccola Rebuild
    By patric in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd July 2012, 09:42 AM
  2. La Pavoni Pro Lever: refurb
    By Rukudo in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th July 2011, 03:28 PM
  3. !!SOLD!!: La Pavoni Europiccola
    By pie_in_ear in forum SOLD
    Last Post: 11th August 2008, 05:57 PM
