Results 1 to 6 of 6
Thread: em 6910, help
    Jan 2009
    5
    em 6910, help
    hey all,
    Ive recently bought a sunbeam em6910 and i have found that after pulling a shot the puck is getting stuck to the shower screen or half the puck will come out and the other half will stay stuck to the shower screen.
    Is this a fault with my machine ? or am I doing something wrong?
    does anyone know how to fix this problem ?
    cheers Malski:P
    Jan 2009
    5
    Re: em 6910, help
    : Forgot to add that I am using a sunbeam em0480 grinder and home roasted beans
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: em 6910, help
    Quote Originally Posted by 616A645C6E666C74030 link=1253008082/0#0 date=1253008082
    hey all,
    does anyone know how to fix this problem ? *
    cheers Malski:P
    Quote Originally Posted by 616A645C6E666C74030 link=1253008082/1#1 date=1253008952
    What basket ?
    Sounds like your under dosing.. and or have a tamping problem and it could be an issue of grind size..
    1: Do teh Sunbeam training...
    2: Do a search and look for the 5 cent piece test..
    Jan 2009
    5
    Re: em 6910, help
    i use the double basket, the shots seem to running all right,
    i tend to dose so its about 3-4mm below the rim after i tamp.
    ill try ajusting the grind maybe ?
    cheers Malski:p
    Feb 2009
    255
    Re: em 6910, help
    3-4mm below the basket sounds about right but my pucks will only stick to the shower screen when I underdose.
    Do as AM suggests and get a 5c piece, place it on top of your tamped puck, lock into place, take back out and the coin should be very lightly impressed into the puck.
    Jan 2009
    5
    Re: em 6910, help
    rightio then, ill do the 5cent first thing in the morning and c what happens.
    thanks guys :)
    Malski:p
  1. 6910 - is this the end ?
    By derrilex in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th December 2010, 03:06 PM
  2. 6910 help please
    By Ali in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 6th May 2008, 05:14 PM
  3. getting used to my new 6910 - but I have some Qs.
    By DIG in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th September 2007, 07:26 PM
