Results 1 to 7 of 7
Thread: em6910 pump pulsing
    Sep 2009
    15
    em6910 pump pulsing
    Hi everyone
    Been enjoying my machine lately until just yesterday i noticed that the pressure gauge showed massive sequential drops and rises when extracting a shot. This has happened a few times since seemingly at random. It results in minimal oily extractions and i generally just cut the shot once i hear the sound of the pump going and then fading then going then fading....
    Anyone else experienced this? Should i be taking it to a repaur centre? its just 7 weeks old!!
    Boots
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: em6910 pump pulsing
    Quote Originally Posted by 676A6A7176050 link=1255049083/0#0 date=1255049083
    Hi everyone
    Tamp / dose / Grind / Dirty / Split seal /
    If ya been OVERDOSING and a bit heavy on locking the system in.. *Ya could be causing a problem.. * And it sounds like it...
    Fine grinds can get in the system.. So do a clean and remove and check out the seal..
    You are using teh single floor baskets with fresh beans and using a top quality grinder...
    Are you not ?
    Mar 2008
    433
    More sounds like your grind was a bit fine and / or underdosed.
    Mine does that when I grind finer and have less coffee in the filter basket.
    Coarsen the grind a bit, dose / tamp so that roughly 1/2 the metal from the SB tamper is above the rim of the basket (3mm from the top).
    Unless its spitting water / coffee out of the top of the portafilter (over the outside) then it is unlikely to be the seal.
    As AM said above, you are using the normal basket (not the dual floor one) and your own freshly roasted / ground beans?
    More often than not, these issues are user related not hardware
    Sen
    10,496
    I agree that it sounds like too fine a grind.
    Jul 2009
    108
    With my 6900 at home i find that alittle tlc goes along way and a good clean and descale works wonders, now with just alittle more info on your behalf we should be able to nail down the areas that might be going wrong for you, AM is a true sunbeam bible, so i usually treat his opinion in high regard,
    have you done the free SB training course because this can help you work out the little kinks
    Let us know the finer points of your coffee making and we will give you as much help as we can
    dont give up on this machine, when refined it makes a great cup of joe
    Sep 2009
    15
    Hey everyone
    Thanks for the input. I think it comes down to the grind for me. Im teetering on the edge of too fine with a bit too much tamp pressure. Ive knocked the grind back on my Granmacinino 1 step and it seems to resolve the issue. Ive also increased the dose a tad to compensate and it seems to have solved the problem.
    When using a doserless grinder, have you guys found a way to keep your dose consistent and repeatable? Also, any tips on tamp pressure.
    Boots
    beans
    Feb 2009
    12
    Sounds like youre getting the hang of it pretty well. Its great to feel your way around your equipment.
    When tamping and dosing, try and keep those two as constant as you can, that way when your extraction doesnt seem right, you can put it down to only a few variables.
    Your tamp pressure can vary depending on what you want out of the coffee, but to keep things standard you can apply say 15kgs of pressure. I usually dose the same amount each time but sometimes I want to "honey drip" the extraction and tamp a bit harder/dose a bit more. This restricts the extraction giving a much tastier shot depending on the coffee. But dont burn it!
    With a doserless, try knocking the loose coffee into the basket as its dosing. Heap it slightly (1/2 - 1cm above the rim) then tamp it. This will ensure you dont waste too much.
    Let me know how you go! ;)
  1. EM6910 pump starts AUTOMATICALLY
    By jjjbbblll in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th May 2019, 09:17 PM
  2. EM6910 pump pressure
    By irishleemurray in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th June 2013, 05:52 PM
  3. EM6910 no main pump, low hot water and steam pump. Had red light. now just not worki
    By bocos in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th February 2013, 09:25 AM
  4. installing new steam pump in em6910
    By crazyhakins in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th April 2012, 08:24 AM
