Results 1 to 8 of 8
Thread: La Pavoni or Miss Silvia
    Oct 2009
    19
    Gday folks how goes it?
    Am looking for opinions on these two machines....
    I know the Miss Silvia is highly recommended in this price range but if I could get a La Pavoni Professional around the same price, which would you recommend?
    Also, there is a La Pavoni grinder which looks alright, but would it do the same job as the Rocky or would it be more comparable to the EM0480?
    Cheers and enjoy whats left of the weekend,
    Lanx
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: La Pavoni or Miss Silvia
    As per other requests...
    It depends on what you want to do ,,
    1: How many in a day / sitting
    2: Milk based or espresso
    3: Who else will be using...
    Most of the machines the sponsors offer are all worth while... But it does depend on what you actualy want to make Vs looks etc...
    Oct 2009
    19
    k, primarily I will make about 5 a day....no more than 3 or 4 in a sitting
    will mostly be making espresso...with the odd milk based option
    and I will be the only using the machine
    Sep 2009
    176
    I started with a gaggia factory which is basically the same as LP professional. I think over all the silvia will produce a better and more consitent result. With the gaggia I found that first coffee was so/so, the second clearly the best and the by the third the machine was usually too hot. There are ways of dealing with this including switching off the machine or using cold water to cool down the group head.
    The benefit of the gaggia, which I would assume applies equally to the La Pavoni, is that its a great way to learn about making espresso. Since you create the pressure (with your arm when you pull down the lever) you really get the feel of what is required to get a good extraction. Another advantage is you dont need to steam milk which I understand is one of few limitation on the silvia.
    Sep 2009
    176
    Ooops I meant you dont need to WAIT to steam milk :-[
    Nov 2006
    979
    Id love a La Pavoni as a toy. But in all seriousness I think the Silvia wins as an everyday machine.
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Silvia with a PID does a pretty decent job. Well with the help of the person on the end of it ;)
    Nov 2006
    979
    Quote Originally Posted by 3A2D2C3227262D797A79480 link=1256441079/6#6 date=1256544962
    Silvia with a PID does a pretty decent job. Well with the help of the person on the end of it *;)
    Likewise a silvia without pid but with a good temp surfing technique, it just takes a little more time as you cant walk straight up to the machine and pull a shot. To be honest im after a couple of years using the silvia im starting to like the wide thermostat. It allows me some instant adjustability for coffee that are either roasted a fraction light or a fraction dark.
  1. !!!SOLD!!! - Miss Silvia Gen 1.
    By jtaus67 in forum SOLD
    Last Post: 18th October 2013, 01:18 PM
  2. Miss Silvia Gal
    By spencarr in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th February 2010, 11:34 AM
  3. RIP Miss Silvia
    By XenneX1969 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 20th July 2009, 06:57 PM
  4. Welcome Miss Silvia!
    By porschemad911 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th June 2008, 08:58 PM
