Results 1 to 2 of 2
Thread: Help - Silvia Noise
    Member SamR's Avatar
    Sep 2007
    79
    Help - Silvia Noise
    My Silvia has started making a strange noise - its like the normal pump sound but higher pitched, tinny & vibrating. Its not necessarily louder than the normal pump sound just harsher. It still works fine when it makes this sound and it doesnt happen always. The machine is kept clean - its back flushed nightly with water & weekly with solution & it was descaled not that long ago.
    Any ideas?
    Sam
    Mar 2006
    703
    Re: Help - Silvia Noise
    Yeah, mine makes different sounds too, but while she works properly otherwise Im in no hurry to do anything.
    Typically after I have descaled her she makes different sounds for a while.
    Could also be a pipe connection to the pump that is very close to an internal panel, and when it touches it could make the type of sound you describe.
    I think I have heard of someone who moved the pump, or insulated the mounts to make it quieter.
    Could be a slightly kinked inlet pipe to the pump which slightly restricts the flow, relatively easy to follow the pipe from water reservoir to the pump.
    Another possibility, could be related to boiler level when you start to pour.
    Silvia was/is notorious for slight leak from the steam wand when you turn her on to warm up, (retension of the steam knob when you turn her on will fix the leak), if there has been a slight leak out the steam wand while she is warming up the first water into the boiler will be resetting the level and at lower pressure instead of producing the normal brew pressure, but I wouldnt expect the sound you describe if this was happening.
    Finally, I have heard of leftover swarf being found in the boiler, which would intermittently affect any water outflows, however cant remember if it sounded different or just didnt flow very well, and this is relatively rare.
  1. Rocket R58 noise
    By Lukemc in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th July 2013, 10:58 AM
  2. brewing noise
    By ale in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th April 2011, 08:24 PM
  3. Noise from Silvia
    By Clonetrooper in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th November 2007, 07:19 AM
  4. Silvia loud clicking noise
    By tintub in forum Brewing Equipment (non-machine specific)
    Last Post: 25th June 2007, 12:11 AM
