Results 1 to 5 of 5
Thread: EM 6910 Cleaning problem
    Jun 2008
    14
    Can anyone tell me why my Sunbeam EM 6910 no longer wants to back flush the way it always has. With the group handle in place I have always pressed the function button until it starts to go silent and then released it. The group flushes with quite a hissing sound. Now the pressure builds up but does not release until the handle is removed. Water oozes out of the hole at the bottom of the machine at the back of the drip tray. When I use a cleaning tablet all the water comes out of the hole at the bottom instead of out of the group head. I had switched the machine on to do this cycle and walked away. I came back to a flood in my kitchen. This has never happened before.
    Jun 2008
    14
    Re: EM 6910 Cleaning problem
    Sorry. I meant to say the manuel button (not the function button)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 7A73614D7077737C120 link=1256992696/0#0 date=1256992696
    Can anyone tell me why my Sunbeam EM 6910 no longer wants to back flush the way it always has. With the group handle in place I have always pressed the function button until it starts to go silent and then released it. *The group flushes with quite a hissing sound. *Now the pressure builds up but does not release until the handle is removed. Water oozes out of the hole at the bottom of the machine at the back of the drip tray. When I use a cleaning tablet *all the water comes out of the hole at the bottom instead of out of the group head. I had switched the machine on to do this cycle and walked away. I came back to a flood in my kitchen. This has never happened before.
    Scale and or a problem with teh solenoid valve... Is what it sounds like, in teh first instance...
    Then again... Are you using teh rubber blind ??
    10,496
    Quote Originally Posted by 232A3814292E2A254B0 link=1256992696/0#0 date=1256992696
    When I use a cleaning tabletall the water comes out of the hole at the bottom instead of out of the group head. *
    I have always pressed the [s]function[/s] manual button until it starts to go silent and then released it. *
    Pressing the manual button is not how you start a cleaning cycle with a cleaning tablet.
    See page 31 of the Instruction Book for the correct procedure.
    However, that doesnt fix your current problem.
    If you havent been cleaning it properly it may be too gunked up to run a normal cycle.
    I hope AM or Graham have a suggestion for you.
    Jun 2008
    14
    Thanks AM and T/God.
    Yes I do use the rubber disc, and my machine is descaled and cleaned very regularly. I am paranoid about cleanliness!!
    T/G you are right about not pressing the manual button when using the cleaning tablet. I only press it when I flush with the rubber disc (we were shown how to do this at the Sunbeam course) The rest of the time I follow the instructions in the book word for word.
    I have never had trouble with the machine until this week and I use it every day. It still seems to be brewing okay. Just the cleaning part is the issue.
  1. Problem after cleaning
    By Joka640 in forum Milk Froth and Bubbles
    Last Post: 12th January 2019, 10:41 AM
  2. Cleaning 6910 question.
    By melv1n in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th August 2011, 09:23 PM
  3. Cleaning 6910
    By RobertC in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th June 2010, 03:42 PM
  4. Cleaning a Sunbeam 6910
    By ajayro57 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd February 2009, 08:46 PM
