Results 1 to 3 of 3
Thread: Servicing a La pavoni`
    Jan 2006
    12
    Wondering if there are any snobs out there servicing their own La pav??
    Time to get mine done, thought I would have a crack at doing it myself.
    Any advice???
    levercrema
    Re: Servicing a La pavoni`
    Quote Originally Posted by 3F282B3F283E2524232A21342A2222294D0 link=1275257467/0#0 date=1275257467
    Any advice???
    What sort of Pav?
    Jul 2008
    Port Fairy
    2,993
    Just in case you havnt found them yet
    http://www.pavoniexpress.com
    http://www.francescoceccarelli.eu/la...storia_eng.htm
    are both excellent starting points :)
    As to tips make sure you have the correct spanners (not adjustable shifters) and depending on model if you want to have a look under the bottom plate for any signs of rust etc. you need a set of Torx bits.
    Last time I pulled my Millennium model down to clean the shower screen and piston only took about an hour, but is was only a clean not a seal replacement etc.
    Only trap for the unwary is the spring clips that hold the handle to the piston, it is amazing how far this sort of clip can travel if you get it wrong ::)
  1. Replies: 31
    Last Post: 13th March 2013, 03:19 PM
  2. Servicing EM6910
    By cammcgrath in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th August 2011, 12:03 PM
  3. Servicing
    By hurgh in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th March 2009, 12:09 PM
  4. La Pavoni servicing
    By MarkC77 in forum Brewing Equipment (non-machine specific)
    Last Post: 24th December 2007, 12:32 PM
