Results 1 to 15 of 15
Thread: Sunbeam EM6910 Problem
    Aug 2010
    6
    Hi Guys,
    Hope someone can help. My Sunbeam em6910 has lately not been sealing properly when i pull a shot.
    It has been happening for a few months now, i replaced the rubber seal becuase i noticed it was cracked, but its still doing the same thing.
    Every shot i pour it spits out the spout but it also runs over the top of the filter basket, past the rubber seal and drips down the outside of the group handle.
    anybody else had a similar problem... ? :(
    10,496
    Re: Sunbeam EM6910 Problem
    Welcome to Coffee Snobs.
    Please update your profile with your location; you never know who might be close by to help with a problem.
    If youve changed the seal that should have fixed it.
    Did Sunbeam give you a set of instructions of how to change the seal?
    Have you changed one before?
    Aug 2010
    6
    Hi! Thanks..
    Yeah i will update my details now!!
    The seal i bought of eBay. I did contact sunbeam they told me to buy it from an appliance place in Ashfield, NSW.
    I havent seen any instruction about changing it. Im pretty technical minded and thought it looked straight forward, so i just removed the shower cap and the seal and swapped it over. It seemed to fit perfectly.
    Would you have a link to online instructions?
    Aug 2010
    6
    Actually ive found a guide online... Looks like ive done it correctly
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 584E49515D48555F040B3C0 link=1281064438/2#2 date=1281065184
    Interesting.. e-bay is usually about 20% plus dearer, by the time postage is added..
    Quote Originally Posted by 584E49515D48555F040B3C0 link=1281064438/3#3 date=1281067691
    Where did you find it ?
    A: What basket are you using ?
    B: What beans ?
    C: What grinder ?
    D: At what point does the group lock in; straight at you = 6 bit over to the right in 5
    E: How old is it and is it Silver or Red
    F: What is the sweet spot ? (Search CS and you will find it.)
    G: When you tamp; how deep into the basket does teh tamp go ? and what sort is it ?
    My guess is that your collar is stuffed... OR has been worn and you can no longer seal correctly. ( Over dosing/misuse/lack of cleaning/Lack of training/ great marketing but poor follow up) AND that ya machine is at least 12 to 18 months old if not older.
    Quick and nasty - but will fix and no collar replacement needed but only if using the older units.
    1: Do a search for Lug mod on teh EM6910... Uses a Dremel etc so think about ya key words in teh search.
    2: Use a spacer - Coffee parts have them - See a post of mine a few days ago... Has a link to the spacer.
    This way, so long as ya collar has not split OR the pipe work in the head has not cracked.. Your group will lock in closer to 4 or 5 but seal on a better surface and more of it.
    PS.
    If ya in the warranty period or it is a Cracked pipe in the head (manufacturers warranty) then get it covered off by Sunbeam.. Do go playing unless it is a last resort.
    AM
    PPS. And use the Advances search function... Saves many of us time as it has all been covered before ;) You not the first and nor will you be teh last :-?
    Aug 2010
    6
    Wow. Ok
    A - The deafault that came with it. But it happens to all baskets.
    B - Happens to All beans
    C - The Sunbeam Cafe Series conical burr grinder. the one that comes with it as a promotion.
    D - Locks In Straight at me, but not that tight. I pretty much have to tighten all the way to the right.
    E - Its Close to 2 years old, Silver
    F - Seached "EM6910 Sweet Spot" not sure what you mean??
    G - Default Tamp - goes in about 2mil max.
    Regretably i havent cleaned it as much as i should have, but lately ive been running a cleaning powder with the cleaning disc, and letting it pour for about 5 - 10 sec.
    Thanks for your help!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Wow. Ok
    giggled like a schoolgirl.. 4 baskets and they are all different.. Which one do you use the most.
    Home roasted / Supermarket / Franchise or Local roaster - How old are they post date of roast ???
    OK.. A correct answer...*;)
    Ok so you lock in at 3 or 2 ????
    OK another correct answer.. *Ps what is *numbers stamped into the black label inside the rear door..
    Learn to use the search function... Advanced search not Quick Search.. *Look for any number of stickies as to how to use the search features *;)
    DEFAULT = *SROFLMFAO * *No such thing.. It is as deep or shallow as *YOU choose to make it...
    3mm at the shallowest and may be 4 or even 5
    At 2mil which is a eng measurement from the USA..
    That is about 2 thousands of an inch...
    Hardly and depth at all... Surprised you can even get the group to start to go in * :D ;) ;D
    Correct terms can some times be very important...
    Do the *5 cent test.... * About to laugh again = *Use the search feature to find out what it is ;)
    That does not sound like what the manual says ?
    1: Remove the shower screen and make sure the SS screans are totaly clean... Then follow the manual for doing a Group Head clean and THEN do a DE Scale..
    I guess you have not changed the filter in the water tank either ???? * ::) ::) ::)
    While you reading and learning... Take the filter out and re charge it in salt water.... *Use the search feature... *;)
    Do not mind me.. My wife spent all night vomiting all over me (no she was not drunk) and after I sent her off to work.. I came down with it and now I am a little tired..
    Just go an spend the weekend searching the EM6910 posts and do some reading....
    Aug 2010
    6
    Quote Originally Posted by 68474E4C5B644847484E4C444C475D290 link=1281064438/6#6 date=1281073534
    Quote:
    Wow. Ok
    I mean defaults.. I use them all at differnt times.. and it happens to all of them. Mostly use the double basket single floor.
    All beans.. I use supermarket , local roasters, single origin. 1 month old to 1 day old. All differnt types.
    It locks in above the K on thermoblock. so all the way to the right.
    OK another correct answer..Ps what isnumbers stamped into the black label inside the rear door.. *
    Black label has 108 stamped on it.
    DEFAULT =SROFLMFAONo such thing.. It is as deep or shallow asYOU choose to make it...
    You said what Sort is it? i said its the default Tamp.. The one that came with the machine. Yeah its about 2mmdeep. So ill be changing that approach.
    Thanks for your help anywayz.
    I had a laugh sounds like you need a coffee
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 3721263E32273A306B64530 link=1281064438/7#7 date=1281160271
    Ok... Single floor basket only... And recommend the Double Shot basket ..
    Ya use the others and I guess your happy to play for a dozen shots re setting teh grind and teh tamp to pull a drink... Your choice...
    Ya just can not help some..... Sounds like a mads womans breakfast.. No Hope.
    Not all teh way to teh right at all.. Ya can go much further than that.. But ya dont know what ya dont know.
    = Collar is stuffed = 99.999%
    2.5 years old.
    Yep. If ya tamping to a depth of 2mm and using all those different stale beans and double floor baskets .. Sorry... Too far gone.
    I leave you to ya own devices... I am Sure you will work it out .... in time.
    10,496
    Quote Originally Posted by 5A757C7E69567A757A7C7E767E756F1B0 link=1281064438/8#8 date=1281161595
    drumatic87 I know where AM is coming from with this.
    You need some consistency.
    Too many variables make it hard to diagnose a problem.
    Send me a PM with the suburb you live in and if youre not too far away I may be able to come and have a look.
    Im not as knowledgeable as AM but have "some" idea. ;)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 625E4358525344515952360 link=1281064438/9#9 date=1281168653
    Im not as knowledgeable as AM but have "some" idea. *;)
    drumatic87 *- * Dont believe him!!!!
    TG is a Strong but Quite Achiever and has had experience with yea old EM6910s...
    Ya snooze ya loose on this offer...
    DONT USE
    Jan 2008
    432
    needs a new collar or thermoblock
    spacer might help if collar
    seal purchased on ebay was probably purchased from us
    graham
    Jun 2009
    214
    This might sound too easy. ::) Have you tried taking the screen + seal out and putting it in again. Sometimes it doesnt sit properly so it leaks. Happened to me when i replaced my seal. So took it out again and put it back in and viola! 8-)
    Well good luck and let us know.
    Aug 2010
    6
    yeah tried that a few times actually I had a laugh.
    Im getting a spacer for now, and will probly buy a collar too.
    cheers,
    Jul 2010
    Sydney's Northern Beaches
    148
    Hi drumatic and Welcome to Coffee Snobs..
    oh, and Welcome to Sunbeam 6910. ;D
    That is all..
  1. Sunbeam EM6910 Steamer problem
    By moffat in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th October 2011, 03:06 PM
  2. Sunbeam EM6910 Frothing Problem
    By lsimpson4 in forum Milk Froth and Bubbles
    Last Post: 22nd April 2009, 12:26 PM
  3. Sunbeam EM6910 flashing problem
    By Eddie.L in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th February 2009, 04:22 PM
  4. Sunbeam EM6910 GH Screw Problem
    By SlikPick in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th May 2008, 12:55 PM
