Results 1 to 4 of 4
Thread: Is this a Synesso double or triple basket?
    Aug 2010
    2
    Hi guys. Ive finally joined after reading plenty of posts and "investing" in a Rancillio Silvia.
    I bought a new Synesso double basket from 5 senses online shop but Im surprised how big it is. It seems to take 50% more grounds (by volume) than the original ridged Rancillio double.
    What do you guys think of the attached photo? Is this a triple, or just a normal Synesso double?
    Cheers!
    Rob
    Aug 2010
    2
    Re: Is this a Synesso double or triple basket?
    By the way. it fits in the normal rancillio portafilter.
    Its possible that photo is on a slight angle making the Synesso look even bigger. I can take another pic if it helps. There are no model numbers on the basket.
    I do seem to be getting much lower flow at the same grind.
    Mar 2008
    23
    Hi Rob, here is my Synesso double up against my Rancillio double. The Rancillio basket measures 23mm high and the Synesso basket measures 25.8mm high. Id say you have a triple.
    Rod.
    Oct 2008
    Sri Lanka
    486
    Looks like a triple to me. My Synesso is from Pullman and its definitely not quite as high.
    I think weighing the amount of grinds in there might give you a better indication.
  1. Replies: 4
    Last Post: 14th June 2012, 10:12 AM
  2. Synesso vs Silvia double basket
    By richardalaba in forum Brewing Equipment (non-machine specific)
    Last Post: 8th February 2011, 05:29 PM
  3. Synesso double basket - 14g or 18g?
    By stevenc in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th June 2009, 06:19 PM
