Results 1 to 7 of 7
Thread: Question when temperature surfing on Rancilio Silvia
    Nov 2010
    24
    Hey guys,
    Had my (2nd hand) Silvia for a month or so now. Getting pretty efficient at pulling some decent espresso shots - just had once question when temperature surfing.
    I generally pull my shot at 45 secs, but im curious - some instructions dont mention it, should I be locking my portafilter in at the start of my 45 sec countdown, or lock it in as close to 45 secs. My friend who has worked at various cafes suggests locking in the portafilter earlier results in burning the coffee.
    Sorry if a previous topic has discussed this.
    Caffeine Junky
    May 2009
    1,103
    Re: Question when temperature surfing on Rancilio Silvia
    If its only a matter of 1-2 seconds before hitting the brew button I doubt that would result in burnt coffee. I guess you could always try a blind taste to see if you can pick the difference.
    Nov 2010
    24
    I guess I will just test that theory. But you wouldnt recommend immediately locking in the pf just as I start to countdown? It is likely to burn a little if locked in for like 30-40 secs?
    14,665
    Hi Daniel,
    The easiest way is to wait for the light to go out, flush the group until you hear no steam and then shoot away. This will produce good and consistent results.
    Nov 2010
    24
    interesting. that way of temperature surfing I havent heard before. how long roughly does it take to flush the steam out?
    14,665
    Quote Originally Posted by 6A6F60676B6263617C696F600E0 link=1295245085/4#4 date=1295302707
    Until you dont hear the steam any more ;)
    Oct 2010
    180
    Quote Originally Posted by 44414E49454C4D4F5247414E200 link=1295245085/4#4 date=1295302707
    If you run the brew switch after the boiler light goes out you should notice quite bit of steam and a hissing sound coming from the group.
    This is more noticeable when the machine is heated for propely.
    It only takes a few seconds. It might take longer or shorter depending on how long the you warm the machine and if you immediately flush water through or wait a bit till you flush the water after the light goes off.
  1. Which temperature surfing Miss Silvia is correct?
    By newbiemocca in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th September 2009, 06:29 PM
  2. Re: Changes to Rancilio Silvia temperature?
    By Robster in forum General Coffee Related...
    Last Post: 28th April 2006, 11:20 AM
  3. Temperature surfing.
    By Boris in forum Brewing Equipment (non-machine specific)
    Last Post: 10th January 2005, 12:48 PM
