Results 1 to 3 of 3
Thread: Em6910 - No pressure to group head
    Mar 2011
    1
    Just given a Sunbeam EM6910 (thought it might make a good spares donor) i have a perfectly working one in Kitchen, used daily) I fired it up and it steams and runs hot water just fine ... problem occurs when using single or double head, no pressure and dribbles of under extracted coffee. If i use the rubber blank in the double , pressure reads into the orange (midrange) but does not go higher (waited a few seconds) if used with single , it reads low orange .. again just tested for a few seconds. would love to get it up to speed - Previous owner tried to replace the group head seal (it now has a blue one) old one on inspection had split... all other functions seems fine as stated.. although it does not make the same noises as my working unit. any advice welcome - happy to take to Melbourne service agent if available. Many thanks Frase :-[
    Nov 2010
    369
    Re: Em6910 - No pressure to group head
    Remove the shower screen and check it is clean.
    you can also then try running water (no coffee) through the machine without the shower screen
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 496B756B4470637167020 link=1299416725/0#0 date=1299416725
    1: The rubber blank with teh hole and Single floor basket and mid range is Fine... All ok.
    2: Have you tries other baskets from you machine ?
    Remember to only use single floor baskets with coffee.
    Try a Double floor basket ( When you look you can see NO light) and NO coffee.
  1. Measuring Group Head Pressure on a HX machine
    By aaronpratt in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th September 2012, 12:35 AM
  2. BZ40 - group head pressure not stable when adding water pressure limiter
    By pup26 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th March 2012, 09:24 PM
