Results 1 to 6 of 6
Thread: BES860 Grinder Malfunction
    Jun 2011
    2
    Hi Guys,
    Long time reader first time poster.. Ive recently bought a BES 860 and being a newbie with these machines, I removed the hopper and thought that I needed to clear out the beans stuck between the burr and the hopper before being able to lock the hopper back in. As I wasnt sure what to do, I thought taking the top burr out would carry all the beans out at the same time, when the contrary occurred and the beans instead when in to fill the top burrs spot.
    Problem now is that I cant lock in the top burr which means I cant use my grinder :( Ive called Breville to ask for a solution but they told me to bring it into a service point and will be charged for servicing. Surely theres a method to get rid of all those beans in the inner burr manually without going to a service center?
    Thanks! :(
    Nov 2009
    Altona, Melbourne
    1,577
    Re: BES860 Grinder Malfunction
    Could you tip it upside down and let gravity do the job? or stick a vacuum cleaner in there and suck them out (gently)?
    Jun 2011
    2
    Dont worry ive solved it, cheers !!
    I kinda just used a butter knife and grabbed the beans out and crushed the ones i couldnt to let it fall further in before being able to lock my inner burr.
    cheers!
    Feb 2011
    Adelaide, South Australia, Australia
    36
    Been there done that - A vacuum cleaner with an upholstery nozzle works well in these circumstances - the moral of the story is to run the grinder until empty (as advised in the manual) before removing the top burr - a mistake we only make once - or in my case twice - but I had a senior moment (at least I think I did but I cant quite remember! :-/)
    Oh, and by the way it should be described as an owner malfunction not a grinder malfunction - the manual clearly describes the procedure for removing the top burr :)
    Jul 2012
    2
    Hi, I recently bought a BES860 and am delighted with it (after internally adjusting the grinder). BUT.....Someone (ok it was me!) spilt some water into the grinder mechanism, which is now full of wet coffee grounds. Ive got out what I can from above, but the grinder still wont grind (due to the remaining wet grinds). Anyone know an easy fix for this or do I have to spend a few hours dismantling? Thanks.
    May 2010
    Sydney North Shore
    1,326
    Quote Originally Posted by 1F383E2528293E02164C0 link=1308199679/4#4 date=1341360821
    Fill the water tank from the right side not the left. Then there is less chance of drowning the grinder.
    Barry.
  1. Should I buy a BES860?
    By KidSetzer in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th July 2013, 06:50 PM
  2. BREVILLE BES860
    By simmoclayto in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th December 2011, 01:56 PM
  3. My First Day with the Breville BES860
    By kate.simpson1 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th December 2010, 10:00 AM
  4. BES860 Breville?
    By sarbear in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st August 2010, 04:46 PM
