Results 1 to 5 of 5
Thread: EM6910 problem...
    Apr 2012
    42
    EM6910 problem...
    My Em6910 is loosing pressure at the group head i think...
    When i lock in the handle and basket and start extraction i get an initial spurt of water out of the group head into tray...
    Only at the begining ...I assume a seal is on the way out...Can anyone advise please ???
    Jul 2007
    153
    Re: EM6910 problem...
    What reading does the pressure switch give?White,yellow,tan,red?
    Jul 2008
    114
    My guess (and it is an educated one) is that either your seal is cactus or your collar has worn down. Either or both may need replacing..
    Apr 2012
    42
    Pressure is still pretty good upper mid range 30 seconds for 60mls....
    I have a new brew head seal to put in...
    If thats not it i will look into collar replacement...Any starting tips for that ????
    Apr 2012
    42
    New seal in and all working ok again althoiugh had to adjust grind and dose as pressure is now up and correct...
  1. EM6910 problem
    By melon in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th May 2010, 07:14 PM
  2. EM6910 blockage problem
    By loppyfo in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th November 2009, 05:01 PM
  3. My Brand new EM6910 ?problem
    By coffeenator in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th May 2009, 05:37 AM
  4. Em6910 problem
    By mmmcoffee in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th May 2009, 10:58 AM
