Results 1 to 5 of 5
Thread: 6910 spontaneous pump startup
    Jun 2012
    8
    Hi folks, got a weird one..
    My 6910 has begun a habit of starting the pump up in the middle of the night.. Two nights running 2am and 3am indeed... Pump only runs for 1 second two or three times 30 seconds apart but enough to wake you up. :(
    Funny thing is its turned off, and is stone cold. Simple solution is to turn off at the wall every night, which is a pain.. It stays on at the wall all day without same issue.. Odd.. Possessed maybe???
    Would be interested if anyone else has had same..
    Perhaps this is my excuse to upgrade to a bes900 anyhow..
    Neil
    Mar 2012
    2
    Re: 6910 spontaneous pump startup
    Hi...had a similar problem when I turned my machine off at the wall for maintenance. When I turned it back on the pump started and would not stop and the machine was not on....only the wall switch. After pumping out around half a tank of water I turned it off, unplugged it and left it unplugged for a few minutes. Never had the problem since. May be turn it off at the switch and switch back on again....possibly does a reset
    Jun 2012
    8
    No joy Im afraid, have left unplugged for hours and same problem - thanks anyhow
    Oct 2010
    139
    I once had some weird pump coming on when the machine was off instances that ended up being due to a few drops of water that seeped in through the top keypad. This can happen if youre not careful when wiping it down etc. Just a thought.
    Jun 2012
    8
    Thanks Yash, I think that was likely it, gave her a rest, dried and all good now
  1. 6910 pump continuous running ...
    By pbange in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th May 2012, 04:46 PM
  2. Sunbeam 6910 pump pressure
    By aussiedean in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th February 2011, 01:12 PM
  3. 6910 pulsating pump
    By derrilex in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th December 2009, 07:01 PM
  4. Sunbeam EM 6910 pump starts by itself!
    By Rodders in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th July 2009, 08:19 AM
