Results 1 to 7 of 7
Thread: Insulating an internal PID? help
    Jun 2012
    61
    Im installing an internal pid in my silvia and want to insulating it. I was going to some how use the aluminium mounting box that the Auber pid came with but not sure how to secure it to the internal surface without drilling. I then thought about making a little sleeping bag out of some sort of heat resistant material that could firmly slide over the body of the pid. I think this would be the easiest but all the heat resistant insulation ive seen on the net seems expensive. ideas?
    Senior Member artman's Avatar
    Jun 2006
    2,375
    Re: Insulating an internal PID? help
    Have you considered double sided tape to secure it?
    Not sure if stubby holder type material is rated to the temps inside a coffee machine, but could work for what you want to do?
    Apr 2012
    495
    The aluminium case it came with wont help you with heat, aluminium is a really good conductor of heat.
    You could try Insul-Brite, its available at Spotlight and such, used for lining in oven mitts, there are several people about who have used it for boiler insulation.
    Jun 2012
    61
    Quote Originally Posted by 535B4B5C4E4A4D5C4B390 link=1341564265/2#2 date=1341617738
    Thanks , i think Insulbrite will be the way to go. Ill make a tube out of it and slip it over it. Do you think glueing a layer of aluminium foil over it would help insulate more?
    Jun 2006
    2,375
    The aluminium foil on the outside of the insulation wont insulate whats inside, it will more reflect the heat coming from the outside
    Jun 2009
    100
    I used closed cell silicone foam to insulated my Silvia. Have been running it with an internal PID for about a year now with no issues.
    It is the orange stuff that a lot of people use, bought it as a kit online precut. Not a sponsor so I can not post the link but if you want PM me.
    Jun 2012
    61
    Quote Originally Posted by MrDerrickC View Post
    I have isulated my boiler etc with the same stuff purchased from PS in the states. Good to know you have had no issues with your pid. Ive been waiting to install my pid until i can get to spotlight to purchase some insulbrite to cover my pid. Im going to simply wrap the pid with insulbrite in a few layers and the cable tie it to the pid and around the wires. I think this would be a cheap and simple way to reflect the heat away from the pid.
  1. Insulating Boiler - Armaflex Anyone?
    By Personality_Juice in forum Brewing Equipment (non-machine specific)
    Last Post: 29th September 2012, 10:14 AM
  2. Boiler Insulating with Armaflex HT
    By Paolo in forum Brewing Equipment (non-machine specific)
    Last Post: 3rd November 2010, 09:58 AM
  3. GS/3 preinfusion through the internal tank
    By robinyong29 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 30th May 2010, 02:48 AM
  4. Insulating boilers (again!)
    By GregWormald in forum Brewing Equipment (non-machine specific)
    Last Post: 25th November 2009, 02:01 PM
