Results 1 to 9 of 9
Thread: Even extraction from a Silva ?
    Jul 2012
    Castle Hill, New South Wales, Australia, Australia
    4
    Hi all, just wandering if anyone has this problem ...
    When I extract either with single or double basket ... coffee comes out quicker from right hand pourer than left. I have made sure machine is dead straight level on kitchen bench and it is.
    Anyone ? This is driving me crazy !
    Sep 2011
    395
    Possibly your tamp and/or distribution is uneven? Have you tried tamping from a different direction to what you normally do?
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,059
    It's possible to buy an adjustable double spout from Coffee Parts, should solve the problem, uneven pour from the Silvia double spout supplied is not an uncommon occurrence.
    Jul 2012
    4
    Is this the one ?
    http://www.thecoffeeman.net.au/AdjstDblSpt
    Would it fit a Rancilo Silva original group handle ?
    Jun 2009
    Moonta SA.
    7,059
    That's the one, $44 plus post seems pretty expensive, suggest you contact Coffee Parts in Syd, would not be surprised if it was cheaper and they will be able to answer any questions, you may have.
    Senior Member sidewayss's Avatar
    Jun 2010
    Perth, Western Australia.
    1,434
    I had the same problem with my Silvia before. The water distribution through the shower screen seemed fine. Technique fine as well, until i found out that the machine was lower on the right side due to the washing machine it was sitting on. A spirit level and a few folded paper later, bewilderment turned to joy as shots came out evenly after that.
    Oct 2011
    Gold Coast
    223
    I think every Silvia owner has experienced this at some stage. Search for "silvia uneven pour" and/or check this thread (it has a few links to other threads too as well as tips for replacing spouts if you go that way).
    http://coffeesnobs.com.au/showthread...ia+uneven+pour
    There are varied opinions as to the cause or causes. Most seem to think it's a tamp issue. In my case that only went part way to explaining things but it definitely was part of the story. I still think one side of my spout is raised or imperfectly machined in some way.
    If you want to check your tamp even-ness and don't have a naked pf you could try this. Grind and tamp as usual, then prise the basket out with a thin knife blade. Rotate the basket 180° and place it back into the portafilter. If you're careful it won't take long and won't disrupt to un-extracted puck. Then check your pour. I don't know if this is a recommended technique but it worked for me until I got hold of a naked pf.
    Or you could just drink doubles.
    Mar 2012
    1,275
    You can check if it a problem with the spouts being uneven by unscrewing the spouts on the PF 180 deg, then see if the pours are reversed.
    If all else fails, you could try "un-leveling" the machine a little until the pours even out !
    Site Sponsor pullman's Avatar
    Mar 2005
    Adelaide, SA
    341
    The adjustable spout option is a band-aid fix really - it may be a satisfactory solution if you've investigated everything else but do that first. 1) make sure your extraction out of the basket is even first. I suggest you use a bottomless portafilter to check this. If you find it's uneven then fix that up (tamp or distribution normally); if not then 2) check the machine is level as already discussed. 3) rotate the spouts as mentioned - if with the spouts rotated the problem stays on the same side of the machine then it has to be a levelling / tamp / distribution issue. If it moves to the other side the spouts may be unevenly formed so change those. If everything checks out OK and it's still uneven I would then (and only then) look at adjustable spouts.
  1. Rancilio Ms Silva Problem
    By mashman in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th August 2010, 07:48 AM
  2. Silva has a problem- pump?
    By warek in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th May 2010, 07:08 PM
  3. Silva miss match
    By jelz in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th June 2009, 10:58 AM
  4. Silva users...info please
    By kopi in forum Brewing Equipment (non-machine specific)
    Last Post: 23rd February 2006, 12:02 AM
