Results 1 to 4 of 4
Thread: EM6910 & Vanish Descaler?
    Feb 2009
    255
    Does anybody know if "Cafetto Vanish Descaler" is OK to use in an EM6910 or is it too strong?
    Senior Member specialpants's Avatar
    Dec 2010
    310
    Quote Originally Posted by shawty View Post
    Definitely not suitable, as the EM6910 contains an aluminum thermoblock. Your best option is to use a citric acid based descaler, which is less harmful on aluminum.
    Aug 2011
    Launceston
    130
    I just descaled my 6910 by using citric acid powder dissolved in warm water and followed the instructions in the manual. Citric acid powder is easily bought from health food shops and is not very expensive. I think I added 3 tablespoons to 1.5 litres of warm water and stirred. I pressed the Manual button twice to run through 500ml, left for 6-7 minutes, repeated the process and ran 250 ml to finish off. I then flushed with 2 litres of water.
    I have used this solution to descale my trusty old Sunbeam EM2300, a Breville 800ES and now the 6910.
    Jun 2010
    6
    Can I descale the steamer with citric acid? The instruction book says I cannot descale the steamer at all but surely it must be done somehow.
  1. Descaler. Which one?
    By Jaishar in forum Brewing Equipment (non-machine specific)
    Last Post: 24th October 2012, 02:21 PM
  2. Descaler/cleaner - quality & value
    By Moonshine in forum Brewing Equipment (non-machine specific)
    Last Post: 20th October 2010, 04:39 PM
  3. Magnetic Descaler
    By grendel in forum Brewing Equipment (non-machine specific)
    Last Post: 26th May 2007, 10:59 PM
