Results 1 to 29 of 29
Thread: Will a rancilio Silvia suit me?`
    Sep 2012
    186
    Hi,
    I've been using a Sunbeam EM3800 now for about 4 or 5 years. Last year I splurged out and bought a EM0480 grinder. I've been pretty happy with the results, but understand that the espresso machine is very basic and the crema I get is mostly due to the pressurised basket. Recently the power button on the EM3800 has broken and I have had to sticky tape it in the on position and the button no longer lights up to indicate that the machine is on.
    This and a nice on-call period has made me seriously consider upgrading my machine. A workmate has reccomended a Rancilio Silvia as a great step up. I do have some questions however and wonder if a Silvia will work for me.
    My partner and myself usually drink short black esspersso's in the morning and may go for a latte or flat whit on a weekend. We generally don't use the steamer as we have a EM0180 frother. I'll also admit that I'll often just nuke some milk in the microwave and pull a shot into that. We tend to buy beans every two weeks and will get them either from my local Cibo espresso bar or from the Adelaide Markets.
    The EM3800 is pretty much foolproof to pull a half decent coffee. Is the Silvia the same or is it much easier to pull a bad shot?
    How long does the Silvia take to warm up to a temperature that will give good results? I have seen a thread on here discussing using a timer to power the machine on ahead of time. Does it take that long to warm up to make that a requirement?
    Do I have to be really fiddly with the grind to get OK results. I don't often adjust the grind setting on the EM0480 now. Will this have to change, or will I still pull acceptable shots with a grind somewhere near where it should be? Is the EM0480 good enough for use with the Silvia
    Does anyone know of anywhere in Adelaide I can do a hands on look at one in store? I'd like to get a feel for the machine. I'll probably order it from Coffee-A-Roma as it seems they have the best price.
    Is the PID really worth the investment?
    Any other comments or advice anyone would like to offer to help me decide wether I should spend the $700 over another $130 EM3800
    Edit: Sorry, meant to post this in the $500-1000 section. Can a mod move it?
    Dec 2011
    46
    I upgraded from an EM3600 to a Silvia and the coffee is *far* and away superior. It does take a bit longer to use though. It also took a few weeks to get used to the grind setting and dosing, but it's pretty consistent now (doesn't need adjusting too often). It is not foolproof though, with practice you get more and more reliable at using it, and in this sense it is a rewarding machine, but it is easier to pull a bad shot.
    The PID makes a big difference, I bought mine from another CS member who already had a PID so I've never used it without one. Time-wise, a lot of the slow down is the result of changing from espresso to milk steaming temperature and back.
    Ideally it should be left on for say, 15 minutes at espresso temperature. But if all you wanted was two espressos from a cold machine ASAP with no PID, one option is to turn the machine on, make sure the boiler is full, and turn the steam switch on. Wait until the unit is at max temperature, and then purge it through the group handle into your cups. I think this would be only about 5 mins after turning it on. Then grind, dose, and the machine should be at the peak of its thermal cycle for making espresso. 30 second shot and you're done. It biggest slowdown is if you want to make say, 4 milk coffees. But this is the case for any machine that isn't a dual boiler or HX.
    Sep 2012
    186
    Thanks for the reply.
    Would be nice to have a PID, but I can't see me investing in one straight away, or buying a pre-modded silvia second hand. Guess I'll have to make do with temp surfing.
    Saw the tip elsewhere of using the steam mode to speedup heating.
    What grinder do you use? I'm slightly concerned that the EM0480 might not grind fine enough for an unpressurised basket.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,058
    Quote Originally Posted by mentasm View Post
    Don't worry about no PID mentasm, I owned and used a standard Silvia for almost 10 years, never saw the need to PID it and we got along just fine.
    Member KidSetzer's Avatar
    Aug 2012
    36
    I use a em0480 with a silvia and I use it between setting 12-14 so there is still plenty if room to grind finer, I've choked my machine using this grinder before!
    Sep 2012
    186
    Great news. I tend to use the grinder on roughly that setting range with my EM3600 as well. Looks like my On-call pay got stuffed up this fortnight so I might have to wait a bit. So tempted to use the old credit card!
    Sep 2012
    186
    Purchase made via coffee-a-roma.
    Excited.
    Dec 2011
    46
    Awesome! Most people agree that temperature surfing and a PID give pretty much the same results, you just need to pay more attention to it I'm using a smart grinder but the EM0480 should be alright, you can always put some shims on it if it's not going fine enough
    Jul 2012
    19
    Hey Meta,
    Silvia 101.
    Before you turn the machine on always make sure there's water in the tank, and the hose line is not cramped.
    For your water get one of these as a an alternative already
    Bombora Coffee & Water Supplies :: WATER FILTRATION :: COFFEE & ICE FILTERS :: Coffee Machine Replacement Water Filter, In-Tank, Resin
    Second whenever you turn on the machine run the brew switch a small amount to prime the pump.
    Third dialing in the grind. Grind a small amount into your palm and press it with your index finger should be fine enough to hold the shape but not take your print. Next place coffee in portafilter and a 5 cent piece in top try to lock it in. Dry shower screen beforehand with a towel. If you find it hard/stiff to lock in there's to much remove portafilter the 5cent should only be slightly disturbed. So repeat process until you get the right result.
    Thirdly get yourself a stainless tamper the plastic one is a piece of sh#$.
    Lastly never run the pump for more than 35 seconds as a rule of thumb.
    Jul 2012
    19
    Another golden rule imo. After steaming run the hot water button with steam tap open until you hear the pump kicks in and fills the boiler. Helps prevent burning out the element. Just remember to point the steam wand into a container as it will spit out water.
    Sep 2012
    186
    I believe my Silvia is in the building. Might get to play with it tonight!
    Got the stainless tamper for $1 with Coffee A Roma.
    Do you think I need the filter if I use a puratap for filling my tank?
    Thanks for the other tips. I'll be back with questions later
    Jun 2011
    12
    You won't be sorry. I've had mine for a couple of years now, make anywhere between 2 and 4 coffee's a day with it using my Rocky. It gets used A LOT. Descale/back-flush it occasionally and it'll stay as good as new. I've never used a filter when filling the tank, though I do occasionally take it out and give it a good clean as even with city tap water there can be a build up of grime after long enough. The steaming might take some getting used to though, but I guess that goes for any new machine! I can honestly say that my machine has well earned what I paid for it. Excellent purchase. Warming up seems to take around a minute for me (maybe I am just occupied with other things). I usually turn the machine on, start up my computer and login... By that time it's ready to go. Though I guess I usually wait around five minutes. If I use steam I always do what another member suggested, I run the water pump until it's full again.
    Enjoy, and post some pics if you can
    Sep 2012
    186
    I've got the machine here now. Impressed with the build quality. Little surprised that I will have to unscrew and remove the top of the machine just to remove the antiscratch film.
    Ordered a couple of the filters linked by InTheCup. Cheap add-on that will ensure long life.
    Don't normally drink much coffee after around 2pm, but I guess I'll be trying some tonight when I get home. Best buy some fresh beans today.
    Thanks for the comments snobs!
    Sep 2012
    186
    pretty happy so far. Was impressed that even from my first shot I was popping out solid pucks. Little bit of adjustment and I was pulling 25 second 30ml shots.
    Must say, dosing the 7gram basket compared to the 18g is much harder. Few practices gave me a decent result.
    The EM0480 seems to grind well for the Silvia, unfortunately though, it's very much designed for the Sunbeam's smaller group head. Had to remove the plastic guide, and find that the coffee is not delivered to the centre of the basket, so some shaking and scraping is required at times to get the coffee where you need it. I'm now looking at Rocky somewhere down the road.
    I am assuming the portafilter loosens up a little eventually? I find at the moment I really have to hold the whole unit in place while locking in and unlocking the portafilter, unfortunately this introduces fingerprints on the nice shiny casing.
    Jun 2011
    12
    Nice. So new looking.
    The portafilter does indeed loosen up a little. Mine I can do pretty easily... I think the little spring object is pretty tight when it's new.
    Jul 2012
    19
    When removing the portafilter is their a minimal imprint of the shower screen or heavy. You may be dosing to much?
    It will loosen up but you shouldn't be needing to wrench it. In addition after use get in the habit of leaving the portafilter locked in (once cleaned) as the heat remaining with the brew gasket exposed can lead to drying out the rubber.
    Jul 2012
    19
    Best quick upgrades IMO is thispidsilvia.com/screen.htm and a Synesso Double Basket - Ridgeless really worth while cheap upgrades.
    I had it on mine when I used to own one and it was really good/helpful.
    P.s. my old machine I miss it and wonder about it whereabouts now?
    http://coffeesnobs.com.au/coffee-har...silvia-v3.html
    Feb 2012
    22
    Re: Will a rancilio Silvia suit me?`
    I also found improvements in the PID and a new filter basket from Talk Coffee. A naked portafilter helps you see and understand what's going on with the extraction a little better.
    Sep 2012
    186
    Thanks InTheCup,
    I had just spent half an hour reading through threads on the screen mod. Feel better about buying a pre-modded part. Was wondering how I would go finding the right screw. Think I'll oprder one of those right now.
    Whats the real improvement with the ridgeless basket? Are the ones that come with the machine really that bad?
    Jul 2012
    19
    Comes complete with screw.
    A warning though, which the seller also states as well.
    When tightening the screw make sure you dont over tighten and it expands under heat it will lock. As it is flat you can't get any leverage to undo it. So as a guide when tighening wobble the part with your free hand and as soon as it stop wobbling give a smidge more and that's it. But well worth it IMO and I never had any problems as with a little care it's not an issue.
    As for the basket having no ridge means tamping is more consisten as the pressure acorss the puck is less likely to be affected by a false tamp so to speak.
    Jul 2012
    19
    Highly reccomend one of these as well if you want to keep your cup warmer scratch free on top of the machine Talk Coffee — Espresso Skinz
    Apr 2012
    Windsor, VIC
    17
    A VST ridgeless basket is a great investment; I found the 18g to be the best for the Silvia. Definitely save up for a good grinder and go for a Mazzer/Compak over the Rocky if you can afford it.
  23. #23
    Sep 2012
    186
    Got my in tank filters delivered today. Whats the life on them you think?
  24. #24
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    247
    The Audrey came with one and it recommends recharging with salt once a month in the manual, but it really depends on how much water passes through it and the hardness of the water
  25. #25
    Sep 2012
    186
    Loving the Silvia so far. Seem to be managing to pull pretty consistent shots which taste great. Found a local bean roaster who's beans I'm happy with (kicco in Adelaide)
    Caved into temptation over the last few days and jumped on a coffee-a-roma ebay auction and am now the soon to be proud owner of a Rocky Doser grinder. Think I managed a great price on it too.
    Still finding latte art quality textured milk a challenge, but have ordered a thermometer to try and help work that out.
    All in all I'm very happy with the Silvia. Great step up into proper espresso at home.
  26. #26
    Mar 2012
    1,275
    Still finding latte art quality textured milk a challenge, but have ordered a thermometer to try and help work that out..
    work through some of the "milk" threads on here, and practice with water + a little dish wash soap.
    BUT..80% of "latte art" is down to the "artist".
  27. #27
    Jun 2012
    5
    Hey Mentasm - You (had) the exact same setup as me!! I've even got the same grind setting!
    Unfortunately though my EM0480 is DYING!
    I bought my machine about 4 months ago and I'm super happy with it - like you said, the steam takes some getting used to, but watching a few videos has helped heaps.
    Let us know how you find your rocky compared to the sunbeam grinder (if there is any comparison), I'm in the market to buy a new grinder and I'm considering a rocky also.
    Cheers!
  28. #28
    Sep 2012
    186
    I'll be sure to drop by and leave my thoughts on the Rocky after I've got him to work.
  29. #29
    Sep 2012
    186
    OK, 3 weeks later and I'm settled in with my Silvia/Rocky combo.
    I've replaced my screen with one imported from PIDsilvia in the US so I have a countersunk screen with a nice flat screw, so no more dented pucks.
    I've also replaced the lid on the Rocky with a ClickClack lid. I couldn't find the exact size, but I wrapped the lid with tape a few times and it now fits tight enough that I can use it to flush grinds out of the chute.
    Managing to get some pretty good consistent results now. Been through about 3 or 4 nice local roasts and have been able to fairly quickly dial in my brew for each. The Rocky produces nice consistent grinds.
    Still having problems perfecting my milk for my weekend milky coffees, but I am getting better. Grabbed a cheap clip on thermometer from coffee aroma which helped a lot
    Happy as hell with the silvia and the rocky over all. All I am missing now is a knock box, which my girlfriend meant to buy me for xmas, but still hasn't gotten around to
  1. Replies: 15
    Last Post: 13th July 2011, 10:55 PM
  2. Replies: 1
    Last Post: 26th March 2011, 08:57 AM
  3. Miss Silvia (Rancilio Silvia)
    By zeke in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st January 2011, 07:59 AM
  4. Replies: 5
    Last Post: 13th November 2010, 08:30 PM
  5. Replies: 11
    Last Post: 5th July 2010, 08:46 PM
