Results 1 to 3 of 3
Thread: Silvia OPV adjustment
    Dec 2010
    395
    Is there any difference (when measuring waterflow out the OPV return tube) between using a blind filter, and using the hot water supply with the steam valve closed? they should both activate the OPV, no?
    Aug 2010
    158
    Do you mean running the pump (middle switch) as you would to flush the steam wand but against a closed steam valve? The OPV does not appear to activate in the Silvia with this procedure and would probably lead to damage to the pump.
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    246
    There is no difference, a blind filter blocks water flow the same as a closed solenoid, the OPV is mechanical and reacts to excess pressure the same regardless of how its created
  1. BZ35 pressure adjustment
    By Shs in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd September 2011, 10:06 AM
  2. Silvia OPV Adjustment
    By fancypants in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th May 2010, 12:17 PM
  3. Silvia pump pressure adjustment
    By SamR in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 15th March 2008, 12:25 AM
  4. Cimbali Adjustment - on or off?
    By cjhfield in forum Grinders
    Last Post: 8th February 2007, 05:16 PM
  5. Nemox OPV adjustment
    By telemaster in forum Brewing Equipment (non-machine specific)
    Last Post: 11th October 2006, 09:39 AM
