Results 1 to 2 of 2
Thread: Mokita combi issue with shots
    Mar 2013
    2
    I scored a mokita combi of friend a while back , the machine is very immaculate not a scratch , but runs very bad shots , i dont know if its a internal issue ,i have been playing around with grinds and shots and basically the shots either rush out , or when i go really fine it cant pull the shot at all ,and basically zero crema on every shot ,and the coffee looks like brewed junk ....
    i have inspected the inside all looks good no leaks , but now im thinking taking it in to a technician to see whats the issues are, the steam works fine ....
    any ideas what the issues may be ???
    Senior Member artman's Avatar
    Jun 2006
    2,411
    Hello and welcome
    They are a very basic and simple machine.
    Are you using fresh beans, less than around 3 weeks post roast? does it need a decent clean of the group, showerhead, backflushing etc?
    Are you dosing the same amount each time?
    Not sure of your skill/understanding of what is involved in pulling a good shot, but plenty of info on this site to read.
    Dose so your finished tamped coffee level is around 5mm below top of basket (you can confirm with 5 cent test) and pull a shot. adjust grind as required to get a good flow keeping the dosing constant. Shouldnt take you too long to get a decent pour, the machine is certainly capable of it.
    If things are still going haywire, check the brew pressure if you have the facilities.
