Results 1 to 20 of 20
Thread: Sunbeam em7000 steam leak?
    Junior Member Jazzymc's Avatar
    Dec 2013
    29
    I've got a "problem" with my newly purchased em7000 which I'm not sure is a problem or might be in fact normal. After frothing the milk and I turn off the steam wand, a small amount of steam still comes out of the wand for at least another 20 seconds or so. Is this normal?
    May 2009
    Bendigo
    1,029
    20 seconds seems a bit long. My 6910 'leaks' for maybe 5 seconds after I turn off the steam - I try to remove the milk just before that happens and then also give it a blast to clear the tip.
    If you don't get a response soon from a 7000 owner, maybe PM Darkfalz and ask if his is like that?
    Dec 2013
    29
    Thanks Journeyman ... maybe it might be slightly less than 20 seconds, but I'm just surprised it just doesn't completely shut off completely when turning off the steam. I find myself also having to remove the milk quickly so it doesn't cause large bubbles to form in the milk as a result of this leaking steam and water
    May 2009
    Bendigo
    1,029
    My normal technique (& it has been discussed on here by others) is to turn off the steam and as soon as pressure drops a bit, remove the jug quickly, directly along the angle of the wand - like you are sliding it off the wand. This means a small amount of steam is still exiting and this helps rpevent milk heading up the tip and causing later issues with blockages.
    I then double up by giving it a blast while I pour or swirl the milk.
    Dec 2013
    29
    Thanks for the tips! Will give it a go. I called Sunbeam and they said a 5-10 second steam leak is normal .... now I just need to time mine to see how long.
    Apr 2013
    Tannum Sands
    30
    mine purges steam for 5 seconds as well
    Oct 2011
    1,376
    Any system will have a short 'delay' between shutting off the steam and flow stopping completely. Depending on the volume held between the valve and the tip, the size of the tip holes, and the density/temperature of the steam.
    If the steam valve is solenoid driven, there may be a 'hidden' closure delay also; between shutting off the steam and the solenoid closing completely. With a manual valve you know exactly when it is fully closed, so the delay would be very short.
    With the right information the depressurisation time can be estimated fairly reliably, but it's not really worth the effort!
    Dec 2013
    29
    Well I just timed it and it's worst than I thought! The steam leaks anywhere between 20-45 seconds, so definitely a fault. Luckily I purchased from DJs, so should be a no fuss exchange.
    Thanks all for the replies, advice and tips, much appreciated
    Dec 2013
    12
    mine does this too - haven't timed it but its over 10s!
    Oct 2013
    35
    If its any help Jazz mine doesn't leak like that at all. I did have a problem with leaking out of the hot water tap but sunbeam offered a swap. Cheers sunbeam.
    Hardleys weren't to impressed though. Two totally different machines to use aswell. I'd take it back if I were you and get a replacement.
    Dec 2013
    29
    I got the EM7000 exchanged 2 days ago, was a little tricky since most DJs were out of stock of the silver and only had white and red. The new one definitely had fixed the problem, steam shutdown in about 5 seconds or less. I was a bit surprised however that there was a difference in the feel of steam wand, the new one felt easier to move, also the hot water came out slightly differently, difficult to explain. There is definitely inconsistencies between the machines, which is a bit of a concern.
    Dec 2013
    12
    Quick question for other users: when your EM7000 is switched on and heating up, at some point in the 'heating' process does it make a sound as though its venting steam/boiling sort of sound? Mine does and I am just wondering if this is normal...
    Oct 2013
    35
    sure does just normal i think mate.
    Apr 2013
    Tannum Sands
    30
    yep, just normal
    Dec 2013
    12
    Cheers With all the minor issues etc floating around on Sunbeam machines its hard to know what is normal and abnormal!
    Oct 2008
    79
    I had a similar problem with mine but it was more around the stiffness of the control. It had to be forced shut....Sunbeam replaced the Machine.
    Dec 2015
    23
    hi, apologies jumping on this thread, our machine is a few years old now and I have noticed our steam takes longer to shut off than it originally did, is there a washer that needs replacing like a tap? Feels like we need to turn it off harder
    Jun 2013
    43
    Mine had the same problem after about a year, had it repaired, I think it was the
    valve, but it started leaking again soon after, and had progressively got worse. I am going to bring it back again. Just as well I bought the extended warranty.
    Dec 2015
    23
    surprised no one has been able to tell me the part I need, its just a valve after all, maybe even just a washer that needs replacing
    I'll keep searching
    Dec 2015
    23
    maybe I need to replace the whole thing Part Number: - EM70019 Machine EM7000 STEAM REGULATOR
