Results 1 to 3 of 3
Thread: Sunbeam EM6910 where is the thermal cut off switch/fuse?
    May 2008
    27
    I have a sunbeam em6910 and all works fine but the power light after warming up continues to flash red instead of green, have read its the thermal fuse/cut off fuse?
    I have a spare machine that's got other issues and would like to use if for parts.
    Does anybody know what part it is?
    thanks in advance
    May 2008
    27
    Ok found a thread that said the cut out fuse is the white button on top of the thermo block. Changed that and no joy.
    I found the same white button on the steamer, more difficult to change but will try this.
    Anyone any ideas?
    Mar 2014
    3
    If it gets to a stage where it allows you to make coffee, I would assume some sort of board glitch?
    They are fiddly little buggers.....if the unit is working I would be inclined to simply continue using.
