Results 1 to 2 of 2
Thread: Brugnetti s40.1 leaky valve
    Sep 2008
    32
    I have a twenty year old brugnetti s40.1 for my jome machine. A semi risky ebay purchase that turned out well: it makes awedome coffees, and wss a massive step ip ftom my Saeco Via Venezia.
    It hss hsd one niggling problem dince new though, which is a leaky vslve at the front of the machine. I'm not sure its actual purpose, perhaps a manual fill.
    Anyways, the issue is that it constantly drips. Does anyone know the lukely cause, and the wsy to remedy? It seems to leak from the lever.
    Cheers, Greguploadfromtaptalk1401101009521.jpguploadfromtaptalk1401101040951.jpg
    Sep 2008
    32
    Yikes spelling. ...
    I took it off and found the problem. It hss a miss-shapen rubber gasket/ rubber plug that is held doen by a small screw. Thst is to say not generic.
    Where can I find this part? What other machines might have the same part/same seal .?
