Results 1 to 16 of 16
Like Tree3Likes
  • 1 Post By Barry O'Speedwagon
  • 2 Post By geebee666
Thread: Heavy duty machine required.
    Jul 2014
    42
    Our Saeco Odea Giro Plus is at end of life and I am looking for a manual machine to replace it.
    We drink around 6 to 7,000 cups a year and the Saeco has lasted 2.5 years but is on its last legs.
    So which of the mid-range machines would cope with this level of usage and make a decent coffee?
    Senior Member Vinitasse's Avatar
    Aug 2010
    Mornington Peninsula VIC
    1,251
    A La San Marco Flexa 85 E would easily handle that sort of traffic. I have put 10,000+ through mine over the past 3 years and haven't had even a hint of a problem yet. It will set you back around $2500 but will last forever.
    Dec 2011
    PRL
    2,722
    Does your doctor approve of that caffeine intake? I'm no wowser, but I hope you throw a few decafs in.
    thegoner likes this.
    Jul 2014
    42
    There is three of us but yes I drink a lot of coffee, no decaf, I don't have any reaction to going cold turkey no headache, even my cardioligist said as long as it doesn't cause any symptoms don't worry about it
    The only draw back is it seems to kill coffee machines every couple of years or so.
    Apr 2008
    Victoria, Australia
    2,099
    Welcome to CS gb.
    Ahhhhh........ caffeine!! So thats why machines wear out!!
    But at 17.8 cups / day between 3 (@6500/year) that's not excessive.
    I would think that any of the decent HX (heat exchanger) machines or Double Boiler in the $2500 +++++ category
    will fill the bill. My Alex II has done 9400 in the two years that I've had the Robur. Purrrrrfect. ;-)
    Mar 2012
    1,276
    Do you really want to change to a "manual" brewing machine ?...
    That is a very different game for someone used to a fully auto.
    If it is to be manual, then most any of the HX "prosumer" type.. ( avoid the basic single boiler types), will easily handle your ~20 cups/day..but you are looking at $2k+
    Look at some of the LeLit range for a start maybe
    But, .. if you have been happy with the coffee and service from the Saeco, it would be hard to not suggest buying another the same.
    They seem to be available for $500 new, a price you would pay in depreciation of a "prosumer" manual machine, let alone what you may probably spend on maintenance also..... Buy a new Saeco every year and save money !
    Infact, you would need to spend another $500 on a grinder to go with most any manual espresso machine.
    Jul 2014
    42
    Not overly impressed with my current Saeco, its had a few issues and the service agent down here hasn't been able to fix one of the current issues after multiple visits, plus its been inconsistent for the last year.
    I have used a cheaper manual previously and have a fair understanding of them, I was looking at the dual boiler or dual thermo block Sunbeam or Breville the problem with the Breville is that its the same service center.
    Grinder wise I will re-wire the Saeco and use its grinder until something good comes on sale.
    I am not adverse to another auto but a manual I hope would have less breakdowns and being able to tweak the flavour more extensively is attractive.
    Mar 2012
    1,276
    Quote Originally Posted by geebee666 View Post
    A manual machine will certainly be able to produce better coffee..providing you take the time to learn to use it correctly.
    but I suspect you will have to rethink that grinder idea if you want the best out of a manual.
    Sep 2012
    274
    What's your budget.?
    I recently passed on a Wega Mini-Nova that was local to me
    was under $1000, used but only 3-4 years old.
    Tough, simple machine.
    Earlier the Double Boiler Lelit was mentioned. and they can be had under $2K easily
    The new Lelit Mara HX will be close to $2k
    But once you go over that mark, the options open up wide in the HX machines and they will all cope with your needs for years and years.
    Stepping away from the auto/ semi-auto appliances give you much better and simpler build quality.
    Here's all the junk that exists within an EM6910, three chinese circuit-boards with soft-touch buttons, micro-connectors and tiny little relays
    And here's the inside of a Double Boiler Manual Italian machine,
    solid switches, big relays (not pictured) boilers a pump and plumbing. An HX machine is simpler again
    Easy to identify and repair if something goes wrong (Less likely)
    Jul 2014
    42
    Well after reading everthing on the net for around a week, I decided to go with a Sunbeam PU6910 reasons being dual thermo blocks, fullsize group, service and parts locally and not the same service center as the Saeco, cost $520 and I paid $89 for a 3 year warranty that also covers wear from heavy use
    So far very pleased it took 3 cups to get a vastly better coffee than the Saeco (used some of the guides/hints from users on Coffee Snobs) so from now on just tweaking, the steamer is 2 to 3 times faster than the Saeco and I can already knock out 3 good coffees quicker than the Saeco can
    Thanks for all the ideas and I did check out everyone of them.
    Sep 2012
    274
    Is that the pack with the 0440 grinder..?
    Jul 2014
    42
    Yes, the grinder seems pretty good, I am currently running it on 8 so plenty of adjustment left and easy to use one handed.
    Mar 2012
    1,276
    Well after reading everthing on the net for around a week, I decided to go with a Sunbeam PU6910....
    ....I paid $89 for a 3 year warranty that also covers wear from heavy use .
    Cannot say i understand how you came to that choice, but a very wise move on the warranty !
    good luck and keep us updated on your coffee journey !
    Sep 2012
    274
    Using the single-floor baskets.?
    Jul 2014
    42
    Yes, I never opened the double walled ones
    Jul 2014
    42
    The grinder took a dozen or so cups to settle in, setting 5 when originally setup choked the 6910 and now....
    I am now on grinder setting 4 and it looks like the perfect setting syrupy dark coffee oozing out and just blonding as the programmed timer cuts out, gauge is in the black/dark brown band, taste is superb.
