Results 1 to 4 of 4
Like Tree5Likes
  • 5 Post By jeremyh
Thread: A "fix" for cracking/peeling chrome paint on Silvia V2
    Jan 2015
    8
    Hello,
    I've gotten a lot of tips out of CS over the years so I thought I would sign up just to post this little tip.
    The chrome paintjob on the (plastic) shroud/cover that goes over the group head on my Siliva V2 had started to peel and crack badly.
    Instead of paying $40+ for a replacement, I just sanded and then painted mine matte black. I used special 'high heat' paint which cost $17/can at Masters.
    The peeling was pretty bad:
    The paint I used:
    After 15 minutes sanding (starting with 240, finishing with 800):
    A number of coats was required, though I didn't use primer. The material seems to soak up the paint and it touch dries in minutes.
    I kept doing coats and giving it a light sand with 800 grit paper every now and again until I was satisfied, probably 10+ quick coats.
    I think the results look great, I probably prefer it to stock. The finish matches the steam knob pretty well.
    Dimal, randyrob, taco and 2 others like this.
    Nov 2008
    56
    Looks good! Good colour match. If you did not know, you might think it was a factory job
    I must admit I have a pet hate for any item to uses that metal bonded foil on plastic. The stuff can peel and sometimes bubbles (thicker foils). I guess the heat and moisture doesn't help.
    Mar 2012
    1,275
    Looks good !
    that shroud is the tackiest part of the Silvias. It really lets down an otherwise solid machine.
    on mine ( since passed on) I saved the cost of the paint, and just used the wet & dry on the brass group.
    a final polish with brasso resulted in a quality looking finish ( but hot to touch !)
    Apr 2012
    497
    Nicely done, if you were really attached to the chrome finish you could always do the same thing with liquid chrome.
