Results 1 to 2 of 2
Thread: Leaking pump - Vibiemme Minimax
    Dec 2014
    Frankston, VIC
    19
    How can I fix this?
    The water appears to be coming from two vertical holes (top and bottom) on the pump.
    Jun 2011
    684
    Fix it by replacing the pump, the shaft seals have failed. At this point there will be water in the bearings of the pump body (bad), and in the motor bearings (very bad) as well eventually.
