Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By TC
  • 1 Post By Matt4007
Thread: Grimac Boiler not heating
    Nov 2013
    13
    Grimac La Uno manual machine
    Havent had any dramas with the machine before
    Now today the boiler wont heat up
    The pump still works and the water is coming through the screen, jut not hot.
    The light at the front comes on then turns off quickly and no pressure is registering on the gauge at the front
    Whats the first steps to diagnose the problem?? Not really that handy when it comes to machines
    Thanks for any help!!
    Mar 2012
    Bathurst
    1,251
    Pressurestat or element control relay most likely. You can replace the pressurestat microswitch with a Cherry D45X. These can be bought on RS Components for a few dollars. You will also need a T10 torx driver to remove the switch from the pressurestat.
    Ensure the machine is unplugged from the wall.
    If no luck, take it to a technician as any further diagnostics/repair would be best left to a qualified person.
    Nov 2013
    13
    Thanks. Are there any guides online for it? I wouldn't even know what part of te machine I should be looking at.
    14,665
    Quote Originally Posted by Matt4007 View Post
    Hi Matt,
    Might I suggest that this is a job for a qualified technician. 240V has produced many recipients of Darwin awards. If you don't know what you're doing, don't do it.
    Dimal likes this.
    Nov 2013
    13
    Yeah I wouldn't attempt myself, have a contact who is very skilled with it so wanted to pass the info onto him. Not my line of work that's for sure!
    Dimal likes this.
    14,665
    If he's a skilled technician, he won't need it!
    Nov 2013
    13
    So a skilled technician looked it it. Boiler is leaking from bottom and element is stuck open circuit.
    Any idea where to source a boiler from????
    May 2004
    439
    You only need a new boiler element and o-ring.
    The distributor should have them
