Results 1 to 4 of 4
Thread: Bes860 54mm baskets
    May 2014
    75
    Bes860 54mm baskets
    Is there any other baskets that will fit in the breville 54mm handle as the standard one's half way down come in a bit preventing the stock tamper from fully pressing down on the coffee.
    As this was my first machine before the silvia I never noticed it to the same extent before
    The oem basket's holes seem pretty good, not to sloppy at all and I have made some good coffee with it
    wondering if there is any other basket that Has straight sides that will fit the tamper all the way to the bottom
    My other option is just get a 52mm tamper and deal with the edges that don't press down fully.
    Asking as others prefer the easier operation of the breville
    thanks all
    james
    May 2014
    75
    I have read that Dalla Corte and La Spaz baskets are about 54mm would some thing like these do
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    845
    La Spaziale baskets are 53mm, I don't know about DC ones though. It does sound like you're under dosing if your tamper is getting that far down into the basket. You don't need it to get all the way to the bottom of the basket, unless you've come up with some new dosing method ;-)
    Rbn
    Nov 2010
    Southland NZ
    452
    Quote Originally Posted by Lovey View Post
    Maybe he is tamping in progressive stages, and wants to tamp the basket when it is 1/3 or 1/2 full.
    Rbn
    Which, is what I do.
