Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By Mouldy
  • 1 Post By Dimal
Thread: BES860 making electrical arcing noise on shots
    Aug 2015
    2
    Hi, have a 4 year old BES860 making some loud arcing noise after i press either the single or double shot button. Machine still extracts but worried something will break soon. Also the machine seems to be making a low level hum too when it's idling. Didn't use to make these type of noises. Any ideas on what's causing it and/or solution would be much appreciated, thanks.
    Aug 2010
    116
    From your descriptions at least, that sounds potentially downright dangerous and therefore I would suggest immediately cease use and unplug from wall, and consult an electrician to inspect and test for any electrical faults.
    If you get an electrician out to look at the machine, then depending on outcome, I'd be also asking them to inspect your main switchboard (Earth leakage breakers etc) and earth stake connection etc for compliance with requirements.
    Alternatively you could take the machine to a service agent and have it tested and serviced. However, if there are electrical issues found I would be asking questions to try and understand if you also need to get an electrician to your home to look at the items mentioned above.
    Dimal and sprezzatura like this.
    Aug 2013
    Adelaide, South Australia, Australia
    208
    I have a bes900, and it makes a noise similar to what I think you're describing. Does it happen as soon as you press the pour button?
    Kind of sounds like an arc, or the solenoid vibrating quickly .. Il try put up a video
    17,552
    Don't muck around with anything that you think may be faulty....
    Often, there are NO second chances...
    https://www.youtube.com/watch?v=yo1diE6FZv4
    sprezzatura likes this.
    Aug 2013
    208
    Is this the sound yours makes?
    I'm taking mine in today
    https://youtu.be/u_2AYDSpjvk
    Aug 2013
    208
    Just had mine return from service, issue resolved as "solenoid valve replacement"
    Aug 2015
    2
    Replaced with Solenoid Valve-Olab 9200H and the noise has gone away, thanks. Yes, noise sounded like https://youtu.be/u_2AYDSpjvk before the replacement.
