Results 1 to 8 of 8
Like Tree5Likes
  • 1 Post By Dimal
  • 1 Post By sprezzatura
  • 2 Post By KJM
  • 1 Post By KJM
Thread: Leaking NS Oscar
    KJM
    KJM is offline
    May 2007
    688
    Leaking NS Oscar
    This machine has not been used for quite a while, and I discovered the pressurestat was not working. So I have a new pressurestat and decided to 'tidy it up a bit' internally. (It is modified - anti-vac valve, flow restricting jets in the group, OPV etc..) Which I did, and turned it on....
    I have a problem with water leakage from the push fit fittings that hold the teflon tube. I think almost ALL of them leak!! I have new tube, and thought I'd just replace the tube. Which I have done, but they continue to leak. Anyone have any bright ideas as to how to fix this? I assume it is some level of dirt in there, but it all looks perfectly clean to me (I removed a few teflon shavings, but it does look clean!). I can see how the thing is assembled, but I don't have a suitable (jewelery sized) pin spanner to unscrew the bit at the end to take the fitting apart. It looks like there is some sort of O-ring or something in the bottom... Given the water everywhere, I'm suspicious of something either aging (O-ring) or corrosion (sitting there for 18months unloved...) since it looks like multiple simultaneous failures..
    Anyone with any ideas?
    /Kevin
    17,122
    Any photos of the offending fittings mate?
    GreenBeanGenii likes this.
    Senior Member sprezzatura's Avatar
    Dec 2013
    Toogoom, QLD
    931
    That manifold assembly is full of o rings - five if memory serves - the press fittings can wear out over time, especially if they're brass gas-style ferrules.
    Dec 2013
    Toogoom, QLD
    931
    The entire assembly is called a 1/4" double fitting. Part number 07300363 - ask one of our sponsors if this part is available as you may need a new one if the press fittings are worn out.
    Aug 2007
    163
    Wonderful! The diagnosticans of CS on board to give aid.
    KJM
    KJM is offline
    May 2007
    688
    Thanks to all.. @sprezzatura - one of the press fit fittings on that part leaks, I'm not after the whole thing, I'm trying to fix the teflon to brass joins. I note that the NS part you quoted seems to have a completely different style of fitting on it Which might say a lot about the durability of the originals. The actual manifold is dead simple to take apart and has two O-rings, both of which I've replaced from my O-ring tins
    I guess I'll need to source some 1/8BSP to teflon compression fittings and just replace the whole lot. Mine is leaking from one of the three on the manifold, one on the HX fill and I suspect the one underneath on the pump, but I've not double checked that. The new fittings they use look like a simple compression/flare with a brass olive in it, so they'll be really simple.
    I'm used to seeing the push fit things on airlines and the like, and they seem to work well there. When I get these off, I will take them apart and see why they've decided to not seal anymore
    Thanks to all for the assistance!
    Mal - the fittings leaking are the ones the pipe goes into in this Youtube vid, but that machine has a leak from the O-ring on the end of the manifold https://www.youtube.com/watch?v=icGWDjo1-9o
    /Kevin
    Dimal and sprezzatura like this.
    Dec 2013
    Toogoom, QLD
    931
    Gas olive ferrules are inexpensive - your local BBQ or gas cylinder shop will have them. If you're near a Pirtek they'll have NSP/BSB goodies galore!
    KJM
    KJM is offline
    May 2007
    688
    Ah! Excellent thought... I also thought about air fittings, but the gas ones are really good... Stupid me not thinking of those! Beer debt to you!
    /Kevin
    sprezzatura likes this.
