Results 1 to 11 of 11
Like Tree4Likes
  • 1 Post By sprezzatura
  • 1 Post By noidle22
  • 1 Post By MrJack
Thread: Single boiler water softening report
    Senior Member sprezzatura's Avatar
    Dec 2013
    Toogoom, QLD
    931
    Just a FYI,
    Here's the internals of a new-style Silvia boiler that's made daily espresso for 6 months. There is the slightest evidence of scale at the base of the bell.
    This machine was descaled twice and always supplied with water that was softened to 4 °dH (71.4 ppm CaCo3/l)
    through a Brita C150 and then a 3M Hi-Flo.
    TH for my area is 89.24 - 93.00 ppm and a ludicrous amount of chlorine.
    pyrmontboy200 likes this.
    Dec 2013
    Toogoom, QLD
    931
    "If you're not a part of the solution you're a part of the precipitate."
    Mar 2012
    Bathurst
    1,172
    Quote Originally Posted by sprezzatura View Post
    I replaced the boiler on a V3 with the new V4 boiler the other week, the customer had been using it for around 6 years on filtered tank water.
    It had no scale or residues anywhere which was interesting.
    Putting a V4 boiler into a V2 this weekend, the machine is from Victoria I think so it will be interesting to see how much scale it has.
    sprezzatura likes this.
    Dec 2013
    Toogoom, QLD
    931
    Hey! Post an image! It's amazing what that tank water does for machine internals, hey?
    mulquemi likes this.
    Dec 2013
    Toogoom, QLD
    931
    Victoria: I had a call out to a place called Pyramid Hill, 2 group Ruggero, presented with totally plugged limestone in the groups, boiler, t/s pipes. It was 18 months old and written off. .5 micron Bunnings sediment drop in filter
    Mar 2012
    Bathurst
    1,172
    Well at least they tried.....with acid or something
    Dec 2013
    Toogoom, QLD
    931
    What is that chunk of crud? Looks like some ferrous stuff.
    Aug 2007
    264
    When I opened my boiler I found a heap of sludge inside. When it had dried it was a little like grey sand.
    I was told that it may have leaked out of the boiler element - some sort of silica insulation that sits between the actual heater element and encasing pipe.
    This would make sense in my case as, although the heater element still worked, it kept tripping the earth leakage, indicating water had got into the element.
    The "crud" in the photos may be something similar.
    Dec 2013
    Toogoom, QLD
    931
    Interesting - I did not know that.
    Dec 2015
    12
    Very interesting...
    Oct 2011
    1,376
    Looks like corrosion products or scale to me...
    www.fwr.org/copper.pdf
    Looking at the freshly exposed copper (pink), possibly added descaler but didn't flush it?
    Dimal likes this.
