Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By JojoS
Thread: Can you damage an element from descaling
    Senior Member yabba's Avatar
    Feb 2009
    Adelaide
    128
    Hi All,
    I have been having trouble with my Simonelli Oscar so I stripped her down for a general clean. I gave the boiler a good descale soak and I chucked the element in the bucket without thought for the contacts. On putting the jigsaw back together it is tripping the power circuits. I will go through the isolation process again tomorrow but it appears that the element is whats tripping the safety switch.
    Is what I did an obvious no no? Are elements prone to shorting out. The integrity of the element is still intact from what I can see.
    Any comments / thoughts /
    Cheers Yabba
    Jan 2014
    Discovery Bay, HK
    268
    Yes it is a no no. You will need to dry them out carefully in a low temp oven for 30 minutes should solve the problem. Test with a multi-meter should indicate if it is still grounded and will need to dry out some more.
    yabba likes this.
    Feb 2009
    Adelaide
    128
    Thanks for the advice.
    Cheers Yabba
