Results 1 to 8 of 8
Like Tree5Likes
  • 2 Post By sysiphus
  • 2 Post By Xanthine
  • 1 Post By kesa32
Thread: Sunbeam 6910 - portafilter won't stay when pouring shot
    Member Aido's Avatar
    Apr 2016
    Brighton QLD & Lennox Head NSW
    41
    Hey all,
    long time creeper first time poster (just registered).
    ive looked through countless threads and can't find anything directly linked so I thought I would ask myself.
    I have a ~7 yr old machine that is a trooper but probably the last year or so I have to hold the handle when pouring or it will untwist.
    im thinking that maybe the group is worn?
    When locked in the PF sits at about 4oclock.
    has anyone else overcome this issue?
    Jun 2010
    11
    Yup - had exactly the same issue. Really should lock in at 6 o'clock. Replaced the group head seal, which helped enough. The root cause, though, was the collar was worn - common problem with the 6910. The new seal worked for a while, but I ended up upgrading instead of really fixing it....
    Magic_Matt and Aido like this.
    Senior Member Xanthine's Avatar
    Sep 2014
    S.A. - South Coast
    203
    Hi Aido
    You may need a shim under the seal - have a look at this...
    http://coffeesnobs.com.au/brewing-eq...am-em6910.html
    Trev
    Apr 2016
    41
    Hey Trev,
    yeh I read that one earlier.
    so the shim goes in and then the seal? Forgive my (most likely) stupid question.
    replaced the deal not long ago so it's most likely just the group is worn I guess
    cheers,
    Aidan
    Sep 2014
    S.A. - South Coast
    203
    The shim above the seal is to make up for wear on the collar and brings the handle locking position back towards the optimal 6 o'clock position.
    If you search the forum for 'EM6910 shim' you will find lots of posts on it -
    Here's another - http://coffeesnobs.com.au/brewing-eq...seal-shim.html
    Collar wear can be reduced significantly by not over-tightening the group handle - you should not have to hold the machine down when tightening it.
    Trev
    Apr 2016
    41
    Tried one piece, it's marginally better(say 5 o'clock). Haven't poured a shot yet.
    will try a second piece but I'm struggling to get the seal out now and don't want to pierce/damage the rubber as I don't have a spare........
    Obviously worn more than some of the other machines out there!!!
    thanks for all the help peeps.
    Aidan
    Apr 2016
    41
    I think the shim has helped but the real culprit is my PF and the tabs being worn so bad that they are beveled and there is no flat section at all to hold it in place.
    Jun 2010
    123
    Hi aido , yeah that and if your up dosing or running high pressure that will certainly make it worse
    Aido likes this.
